What's the best axle to buy? - Fiberglass RV
Old 01-28-2008, 06:59 PM   #1
mcnick's Avatar
Trailer: 1981 13 ft Scamp / 2004 Ford Explorer
Hey everyone,
I am about to buy a new axle for my little 13ft Scamp. I was going to call Scamp today when I got to thinking if Scamp's would be the best one to buy..?? On one thought I know it will fit and have all the right spec's for the camper, but then at the same time I am thinking is there a better one out there for a better price??
So I am here asking all my fello Fiberglass RV'ers for their advice on what I should do.
Thanks for the help!
mcnick is offline   Reply With Quote
Old 01-28-2008, 07:04 PM   #2
Scamp doesn't make their own axles. They're either Al-Ko or Dexter. I replaced an Al-Ko with a Dexter on my Scamp a couple of years ago because of availability. Between the two, I'm not certain there is a "best." Other's will pop in and give their two cents worth too.
Old 01-28-2008, 09:40 PM   #3
Trailer: Casita 2000 17ft. Liberty
Leading or trailing it does not make any difference. The arm is so short and the rubber torsion so stiff that nothing will move up or down very much.
Why not drop the issue?
jim munson is offline   Reply With Quote
Old 01-29-2008, 04:41 AM   #4
I don't understand this post Jim. Are you saying he doesn't need to replace the axle? I found replacing the axle on my trailer made a huge difference in the way it towed. No more bounce, no more feeling like it was bottoming out.
Old 01-29-2008, 03:32 PM   #5
Pete Dumbleton's Avatar
Because some earlier trailers were set up for leading arms. Dexter, for one, no longer makes a leading arm axle and on some trailers the mounting must be therefore be changed because the main axle beam of a trailing arm won't fit on a "drop in" replacement. A legitimate consideration.
axle
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
Need a new axle? Rarebird Towing, Hitching, Axles and Running Gear 2 01-31-2008 01:56 PM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
Axle JohnWalker Towing, Hitching, Axles and Running Gear 5 04-21-2006 07:57 AM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
