What tire pressure for 12 in tandem tires - Fiberglass RV
Old 08-11-2017, 11:20 AM   #1
I have a Fiber Stream trailer with tandem axles and 12 in tires. The trailer weighs about 2500 lbs fully loaded. I think each axle is rated for 1800 lbs. The tires say max pressure is 80 psi. For such a light load I am thinking 80 psi is more than I need and will just add to harsh ride. I am wondering if 60 psi would be enough allowing a little more give and less bounce while towing.
Any thoughts?
Thanks,
Steve
slbran is offline   Reply With Quote
Old 08-11-2017, 11:51 AM   #2
What's the tire rating?
Old 08-11-2017, 12:11 PM   #3
Any thoughts?
Thanks,
Steve
You might be old enough to remember the Ford Explorer problems with tire pressure. Look it up.
What is generally recommended by the tire manufactures is use maximum side wall pressure. In your case it would 80psi. Trying to soften the ride by reducing tire pressure is asking for trouble in form of blow outs. The more the side walls flex the hotter the tire gets and eventually it makes a loud noise that you probably won't hear. Might ruin your whole day.
Old 08-11-2017, 12:16 PM   #4
The tires are Load rang C - 475 lbs.
Old 08-11-2017, 12:49 PM   #5
That doesn't seem right. 475 pounds x 4 tires = 1900 pounds maximum on the tires. If your trailer weighs 2500 pounds, you're probably carrying more than that on both axles combined.
How about the manufacturer and size of the tires?
Old 08-11-2017, 03:36 PM   #6
You are correct Jon. The tires are a little hard to read. It is 475 Kg and 1000+ lbs (can not read clearly).
Size is 5.30 x 12.
Old 08-12-2017, 10:00 AM   #7
Try looking up the LOAD/INFLATION chart for that type and size of tire.
Maybe the Tire and Rim association handbook.
Goto a scale and get the actual weight on the 4 tires.
Divide by 4, set the air pressure accordingly.
A simple rule of thumb: if you see no bulge in the sidewalls they may have too much air.
Old 08-12-2017, 10:01 AM   #8
Size is 5.30 x 12.
475 kg = 1047 lb.
Old 08-12-2017, 10:01 AM   #9
bill&sandra's Avatar
Trailer: 13 ft Scamp
Send a message via Yahoo to bill&sandra
475 Kg is 1045 Lbs. That is @ 80 psi. The load rating drops very rapidly with lower pressure. Don't try to ease the ride by lowering the pressure, early tire failure is that future. Most trailer mfg tell you to use the tire mfg sidewall inflation info molded into the tire and will tell you what size / rating tire to use (B, C, D, etc).
bill&sandra is offline   Reply With Quote
Old 08-12-2017, 10:27 AM   #10
Another consideration:
Are the two axles mounted on an equalizer suspension? or separately?
If, the latter, it's possible for all the weight to fall on one axle when going over humps or dips. If so, I will bow to the max pressure folks.
Old 08-12-2017, 10:04 PM   #11
Mine does have the equalizer between the springs.
tires
Tire pressure on new trailer tires Tony Nowak Towing, Hitching, Axles and Running Gear 9 09-04-2009 05:14 PM
Tire Pressure Ron and Alma Care and Feeding of Molded Fiberglass Trailers 7 04-22-2006 04:01 PM
trailer weight , tire pressure , sagging axle Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 05-17-2003 11:40 AM
Tire losing air pressure. Legacy Posts Problem Solving | Owners Helping Owners 4 02-07-2003 01:55 PM
Gas mileage vs. tire pressure General Chat 0 01-01-1970 12:00 AM
