12-09-2010, 07:04 PM
Trailer: 1985 U-Haul CT13 ft ('The Mothball')
What to buy for city driving and occasional towing.
Hi all,
I am interested in suggestions of what to buy for a tow vehicle. I drive a lot in the city for work and want a small, very comfortable and reliable car but also one that can tow my U-Haul on weekends. Also I prefer a higher-end hatchback.
This will be an upgrade car and I am currently considering a Volvo c30 but wondered what the forum might suggest.
My U-haul is a CT, about 1500lbs I believe. It does not have brakes right now but I am willing to put them on next year. I currently tow with a Subaru Impreza but I would like a vehicle that is easier to parallel park in the city.
Thanks,
Bridget
12-09-2010, 08:11 PM
I towed a 13 ft Burro with a Honda Element. It suited both of the needs you specify to a T.
Doesn't the UHaul have surge brakes? I thought they all came that way. If not, you will definately need brakes of some sort.
12-09-2010, 10:47 PM
Trailer: 1984 Scamp 13'
Maryland
I don't know what your feelings are about tow ratings. I tow with a Scion xD, which is similar to a Toyota Matrix. In the US, they don't give a tow rating, but the same car carries an approximate 1,700 pound rating in other countries. Likewise, the Honda Fit carries a 2,200 pound rating in many countries.
If you want a car with a good rating, check out Subarus.
-Jesse
SOLD! - 1984 Scamp 13 in Maryland.
12-10-2010, 09:56 AM
Trailer: Escape 17 ft Plan B
You might look at a V6 RAV4 with tow package...
12-10-2010, 10:09 AM
Trailer: 93 Burro 17 ft
Oklahoma
Agreed. I test drove a Rav4 before buying my Highlander and the Rav has an unusually tight turn radius. Which means it will turn more sharply for parallel parking. The salesman had me do a tight circle in a parking lot and it brought a smile to my face. If I hadn't wanted the higher (5000 lb) tow capacity of the Highlander, I would have bought the Rav4. Get the V6 engine and you'll be happy.
on edit: I looked up the turn diameters of the vehicles on autos.msn.com (under Specs & Features: Exterior) and found these numbers:
Impreza 34.8 ft
Volvo C30 38.1 ft
Rav4 34.8 ft.
So actually you have a really tight turn on the Subaru already! The Volvo will be harder to maneuver into parallel spots, not easier. To get a tighter turn and more maneuverability than what you already have, you may need to go to something as small as a Toyota Yaris (30.8 ft) or Prius (34.2 ft, 50 mpg hybrid)... but these smaller cars are not usually rated for towing.
12-10-2010, 06:37 PM
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester
Impreza 34.8 ft
Volvo C30 38.1 ft
Rav4 34.8 ft.
The 2011 Subaru Forester has a 34.4 ft turning circle and a rated towing capacity of 2400 pounds. We are using a 2003 Subaru Forester for towing our 13 foot trailer and it does it very well and it is a great car for driving also. Consumer Reports rated the Forester as the top small SUV.
Brian
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
12-11-2010, 03:38 PM
Maryland
Toyota rates the Yaris to tow up to 1,984 pounds with the 1.33L gas engine or 2,315 pounds with the 1.4L diesel. They don't offer the "big" 1.6 liter US spec engine in the UK, so I was not able to find a tow rating for it.
Toyota Motor North America does not list tow ratings foe their cars. They will happily point you towards a truck instead.
-Jesse
12-11-2010, 04:43 PM
Always so interesting to see how your comment is interpreted! Of course my desire to 'have something easier to parallel park' could mean the turn radius, but actually I meant I would like a shorter car!
Also I'm surprised to find out that the turn radius of the impreza is good, I don't find it that tight really, but my last car was a civic hatchback.
Thanks for all the comments, keep em coming. I'll let you know what I get.
Bridget
12-11-2010, 06:43 PM
Trailer: 1972 Compact Jr
You are facing the question I recently answered. I was needing to replace a failing Subaru Legacy wagon, 5 sp. I also wanted an economical car, trying to stay with a 4 cyl and able to tow 2000 lbs. We looked a lot. Since there was just two of us we were going to go with a Toyota Tacoma extended cab, 5 sp. which is actually very good on fuel. The volvo dealer suggested a XC 70 with all wheel drive for towing. We ended up with a gently used Volvo V 50, 5 cylinder, better fuel consumption than the subaru, and since used , a lot cheaper. Automatic transmission with sport shift. Its very comfortable to drive. Have yet to tow, that will be when warmer weather comes, tow capacity is 1900 lbs.
Another vehicle that surprised us was a Kia Rondo, V6.
12-11-2010, 09:46 PM
Maryland
Typical American dumbing down of the tow ratings... Your car has a 3,300 pound tow rating in Europe. Of course, you'd need a Euro hitch to tow that much. Not surprising, though... A VW Golf also has a 3,300 pound tow capacity.
-Jesse
12-12-2010, 03:58 AM
We ended up with a gently used Volvo V 50.....tow capacity is 1900 lbs.
Time for my usual comment about European tow ratings - that they assume a legal towing speed limit of 50mph and a hitch weight %age as low as 4%, instead of the North American 10% - the higher hitch weight %age increases high speed stability and so allows higher towing speeds.
The V50 in Europe is limited to a 75kg/165lb hitch weight so if you want a North American 10% hitch weight, that would give a 1,650lb maximum trailer weight.
While checking the Volvo's hitch weight ('nose weight' in England), I came across this description in a Volvo towing guide:
Tough durability tests
As well as its towing tests at home in Sweden, Volvo Car Corporation also tests its cars in Death Valley, California. In extreme heat, with temperatures well over 40 degrees, test cars are driven with fully loaded trailers on a 23.3 kilometre long uphill climb with an average gradient of 7%. Nowhere else in the world can a tow car be subjected to such extreme trials. All Volvo cars have to go through this extreme test before the test engineers give their approval.
12-15-2010, 09:22 PM
So,
I test drove a used 2008 subaru impreza hatchback today which seemed quite nice to drive. But it has no tow rating. Now my present car is a subaru impreza wagon and I tow the U-haul with that OK, rating is 2000lbs without brakes I believe.
Now to test drive a volvo C30, and to consider what other hatchbacks might be able to be a good small city car but also tow the U-haul.
Thanks for the advice so far,
Bridget
12-15-2010, 09:35 PM
Originally Posted by Bridget T
So,
Bridget
Bridget:
Have a look at Subaru Warranty, and Towing information page
It says Subaru Impreza has 2000 lbs towing capacity with brakes.
Brian
Brian & Maria
12-17-2010, 11:23 AM
Originally Posted by Brian Van Snell
Brian, This is what it says:
Impreza
Subaru doesn't supply hitches for the sedans or recommend towing and so it is not suggested or recommended and there is no offficial approval. Warranty could be affected by any towing.
Plus, this site is not a Subaru site, but is maintained by Joe Spitz.
Now Joe may be a fine individual, but he is not an official Subaru spokesman.
I would only rely on official Subaru documents for any information re: Subaru vehicles.
12-18-2010, 06:08 PM
Hehe Joe Spitz is actually a Subaru salesman and I bought my last car from him. Was a nice guy and a great help to me in getting my car cleared back to Canada but agree his info may not be totally up to date.
Bridget if you are going to stay with Subaru I would suggest you take a good look at the Forester or Outback. My Outback spends a better part of its life driving in a city.
12-18-2010, 11:06 PM
Name: Borden and Carole
Most cars can pull the 13' at that weight. You only need a class I hitch 200 / 2000. With trailer weight of 1500 lbs. plus gear maybe 2000 lbs. you are still in line.
mcbrew is right other areas give different rating on towing in fact I have pulled in the past a trailer that loaded weighed 1500 lbs. with our old Echo sedan; although I would not recommended it, I do admit it did work fine. They make a class I hitch for it.
A transmission cooler and trailer brakes are always a good idea. Mr transmission sells a progressive transmission cooler unit that is quite nice. It is important to control heat but not over cool a trans-axle.
Happy camping
02-03-2011, 12:58 PM
Trailer: Lite House
I'm in the same spot. I currently tow my Lite•House with a 4cyl 2.4 L Tacoma. My truck is 10 yrs old and has almost 170K on the odo. Like the OP, I do a whole lot more commuting and city driving than towing.
My camper is small, even by the standards of this forum. The original ad for the Lite•House lists a dry weight under 1000#. The trailer has no brakes.
I've thought about another Tacoma, but would really like something a bit more comfortable. So far, I've considered the Outback but Subaru says trailer brakes are required. Now I'm vacillating between a Venza and a Highlander. I want to stay with a 4cyl because I'm not interested in making Texas oilmen any richer.
I'd appreciate any suggestions, thoughts or sage advice.
02-03-2011, 08:41 PM
Trailer: 2009 Escape 17 ft
I'm a Subie fan (we have two Outbacks - one with ~300k miles!)...
I'd buy an Outback and add brakes to my trailer...
Then again, I had brakes on the teardrop I just to have. I don't think many newer cars have much extra braking capacity.
The other cars you mention are probably nice too
Paul & Norma
2005 Hunter Fat Shadow, 1995 Scamp 16, 2009 Escape 17B, 2013 Escape 21
2022 Coachmen Nova 20C
02-03-2011, 08:50 PM
Trailer: Escape 19 ft
FWIW,my (bias) vote is for the Highlander - nice vehicle!
02-03-2011, 09:16 PM
I have a Subaru Outback and love it, but I agree, without brakes you're limited to 1,000 lbs on the Subaru.
Another vehicle we had in the past that was an excellent stable towing platform was the Ford Escape with a 4 cyl and manual transmission. I believe they're rated at 1,500 but not sure with the latest models.
John
