Wheel and Tire Combo - Fiberglass RV
Old 05-11-2013, 09:02 AM   #1
Trailer: 2010 Escape 17B
Is there any reason you couldn't use these on the Scamp/Boler type 13's? Same size tire etc.
13" x 4.5" White Spoke Trailer Wheel with bias ST17580D13C Tire Mounted (5-4.5" bolt circle) : Amazon.com : Automotive
They look similar to the ones Scamp uses, we just bought some for our boat trailer which got me thinking as they are a good price.
kootenaigirl is online now   Reply With Quote
Old 05-11-2013, 09:25 AM   #2
As long as the bolt pattern is the same, they're zero offset, the center hole is big enough and the tire isn't so wide it won't fit in the enclosed wheel well, you could use them.
Shipping might be a killer though...
Old 05-11-2013, 10:18 AM   #3
John J. M's Avatar
Trailer: 73 Boler and 78 Biggar
to get my tires on the boler , the trailer has to get jacked up really high to squeeze them in , , not easy ,but worth it ,I feel .
John J. M is offline   Reply With Quote
Old 05-11-2013, 04:55 PM   #4
Brian B-P's Avatar
The listed tires are bias-ply; the online Scamp 13' specs say
13" B load radial
I won't launch the radial versus bias-ply debate here, but it is a difference to be considered.
The proposed tire is Load Range C (while the Scamp original equipment is Load Range , which is also a difference, but that's harmless... unless it causes the owner to be confused about inflation pressure. Again, not a debate which needs to be run again in this thread.
I agree, with the addition that the overall diameter is not large enough to cause fit problems.
Old 05-11-2013, 05:11 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Specs for newer trailers aside:
If you're talking specifically about the 1975 Boler in your profile, I wouldn't be surprised if these tires were a near-perfect match to the original tire specs.
As noted above, the wheels could be a different story, so checking the mentioned dimensions very carefully would be in order...
Francesca
Old 05-11-2013, 05:33 PM   #6
We bought about the same thing for about 2 for $175 at a local Pep-Boys store and they checked and corrected the balance as well. Took 3 days to order them. You might check with Canadian tire etc in your area.
However, be prepared to get an off brand Chinese tire and be sure to specify that they can't be more than 6 months old at delivery.
Old 05-11-2013, 10:30 PM   #7
Thanks for the input everyone. Wheels seem to be tricky maybe I'll just get new tires
Old 05-12-2013, 09:14 AM   #8
Brian B-P's Avatar
That's supposed to be ST175/80D13 LR-C, or
ST - Special Trailer spec class
175 mm nominal section width
80% aspect ratio
diagonal (bias) ply construction
Load Range C
No, the Boler original is likely 600-13, A78-13, or B78-13, any of which are significantly narrower than the 175 mm width of the new tires; the "600" means 6 inches, and 175 millimetres is about 7 inches. The proposed tire is wider, taller overall, and a higher load range; it matches only in rim diameter and construction type. Since the original width is generally no longer available, this mismatch is commonly faced by B1300 owners.
As noted above, the wheels could be a different story...
Yes, the new wheels could be wider (which won't likely be a problem if the tire width is not), and the original whells might have 1/2" offset so if the new ones have zero offset outer sidewall to fender lip interference might be an issue. As Donna noted the bolt pattern must match, and while the proposed wheel has 5 bolt holes, the original likely has 4.
Old 05-12-2013, 09:17 AM   #9
Brian B-P's Avatar
Although these wheels may not match, if your trailer has 4-bolt hubs most 4-hole trailer wheels are the same and will work. Wheel+tire combinations are very common for trailers, especially from stores that don't have a shop to do tire mounting, so they can be a good deal.
Old 05-12-2013, 09:58 AM   #10
Yes, my wheels and tires now are not original. They are 5 bolt and the same tire size as the ones on the link.
Boler Wheel and Tire 67dodge Problem Solving | Owners Helping Owners 9 09-23-2011 08:44 PM
Tire and Wheel Bearings Question Doug1234 Towing, Hitching, Axles and Running Gear 4 09-11-2011 05:34 PM
Boler Tire / Wheel Question Peter_Crowl Care and Feeding of Molded Fiberglass Trailers 8 05-07-2011 03:06 PM
Scamp Tire wheel upgrade? Nolan Scheid Towing, Hitching, Axles and Running Gear 5 09-18-2007 06:27 PM
Tire & Wheel william russell Classified Archives 0 10-29-2006 10:54 AM
