Wheel bearing size for 77 1300 Trillium - Fiberglass RV
Old 03-17-2015, 04:44 AM   #1
South Carolina
I am planning to replace my wheel bearing on my 77 1300 Trillium. Can anyone tell me what size of bearing to buy to do this?
Dennis77 is offline   Reply With Quote
Old 03-17-2015, 06:11 AM   #2
Martins HeirCon's Avatar
Trailer: Trillium 1300
I'd recommend removing a set and matching them. In nearly 40 years, the axle may have been changed.
Martins HeirCon is online now   Reply With Quote
Old 03-17-2015, 07:30 AM   #3
Trailer: 2014 Escape 21
Virginia
Dennis
If they aren't bad just clean an repack them, they are more than likely better quality than what you buy today. If they are bad follow Glenns advice.
My guess is they are 1" straight shaft bearings. (But just a guess.) The most inexpensive way is to get a trailer bearing kit. which includes two bearings, races and seals for a 1" shaft the kits run about $15. Wally World sells them in the boat section and Northern Hyd. also sells a kit but with much better seals.If you just need seals Northern sells two ea. seal kits. I had trouble finding the P/N the 1.98" seals for the 1" spindle but I can dig it up if that is what you need. Any trailer parts vendor will have the parts you need.
Eddie
trillium
HUB Bearing/Repack DIY - 1976 Trillium 1300 - georgewa Modifications, Alterations and Updates 6 10-18-2013 11:44 AM
1976 Trillium 1300 wheel bearing seal size georgewa Modifications, Alterations and Updates 2 08-10-2013 11:44 AM
Size of wheel bearing seals - Bigfoot Carol Crawley Towing, Hitching, Axles and Running Gear 8 06-14-2010 11:03 PM
Problem With Wheel Bearing Randy Bishop General Chat 0 12-31-1969 07:00 PM
