Wheel Size - Fiberglass RV
Old 12-01-2009, 07:13 AM   #1
Filbert V.'s Avatar
Trailer: Tote N Tarry
I don't know much about wheel sizes and what will fit on my Tote n Tarry. I would like to replace the stock 13 inch rims with some off a 1964 Ford Falcon. The size of those wheels are 205 75R 14 and are the 5 bolt pattern like the 13 inch I have now. Would these fit or even 15 inch rims fit on my trailer without modifications of the fiberglass wheel wells? Also, one wheel on my trailer has lug nuts, and the other wheel uses lug bolts to keep them on. Is this normal? Thanks in advance for your help.
Filbert
Filbert V. is offline   Reply With Quote
Old 12-01-2009, 10:57 AM   #2
Unhappy
I cannot address whether your idea of using Falcon wheels would be problematic or not. I hope someone else can address that.
Also, one wheel on my trailer has lug nuts, and the other wheel uses lug bolts to keep them on. [b]Is this normal?
Um, I don't think so.
My Fiber Stream was originally configured with lug bolts on all 4 wheels. Then the original brakes (on the front axle only) wore out. They were some other brand; now Dexter is the only manufacturer of 7" brakes. Now I have new Dexter Brakes on the front axle that have studs on the wheel hub and lug nuts to hold the front axle wheels on. My rear axles retain the lug bolts.
I suspect that at some time in the past one of your wheel hubs had to be replaced, and that the one with lug nuts is newer than the one with lug bolts.
Size of wheel bearing seals - Bigfoot MountainHome Towing, Hitching, Axles and Running Gear 8 06-14-2010 11:03 PM
72 Boler American wheel hub size? Brian Scott Towing, Hitching, Axles and Running Gear 4 11-03-2009 06:28 PM
Interior height and bed size in Bigfoot 5th wheel? Lizbeth General Chat 6 09-17-2008 11:41 PM
Trillium 5500 -- wheel size? Janice M Towing, Hitching, Axles and Running Gear 5 08-23-2008 11:40 PM
Wheel size Legacy Posts Modifications, Alterations and Updates 20 04-23-2003 10:48 AM
