Wheel size - Page 2 - Fiberglass RV
Old 02-01-2014, 11:38 AM   #15
No need to upsize if additional weight-bearing capacity is the concern. The 13" tires supplied by Scamp are load range "C", but they can be had in LR "D", too. ( Link)
That step up in range achieves an increase in load bearing capacity from 1360 to 1725 lbs.- per tire, of course.
And without changing the trailer's wheels!
One caveat:
This presumes that the trailer wheels in question are rated for the higher (65psi) pressure of the LRD tire. Such info is usually stamped on the wheel itself.
Francesca,
I changed wheel size to 14" to gain weight capacity. At the time I didn't see availability of the tire in your link. I could have saved a lot of money!
Oh well, It was a fun project, and I have new suspension now.
Russ
Old 02-01-2014, 12:41 PM   #16
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by ruscal View Post
Francesca,
Russ
I'm glad you brought suspension up, Russ. I forgot to point out in my earlier post that in all cases, the lowest capacity component of the system governs carrying capacity. In your case, I presume you have the 3500 pound axle that appears to be standard on the Scamp 16, so you have enough capacity there to reap the benefit of higher-weight bearing tires etc.
But of the two 13 footers the O.P. is considering, that is only true of the Casita 13, which also comes with a 3500 pound axle. Link to specs
(Side note: Strictly in my opinion, that's too much axle for such a small trailer...I suspect it would result in a really harsh ride unless the trailer was loaded close to 3,000 pounds or so.)
The Scamp 13, on the other hand, has a 2200 pound axle. Link to specs That's its limiting weight-carrying factor. Neither upsizing nor increasing LR of tires will result in an actual increase in carrying capacity.
And here's a bit of unsolicited advice to the O.P.:
This is the first time I've ever looked at the specs for these two 13-ers side by side...the Casita being so much heavier (even "dry"), it seems to me that if keepin' things small/light is a primary aim the Scamp would be the better choice.
With the 13" tires!
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
72 Boler American wheel hub size? Brian Scott Towing, Hitching, Axles and Running Gear 4 11-03-2009 05:28 PM
Interior height and bed size in Bigfoot 5th wheel? Lizbeth General Chat 6 09-17-2008 11:41 PM
Trillium 5500 -- wheel size? Janice M Towing, Hitching, Axles and Running Gear 5 08-23-2008 11:40 PM
Wheel size Legacy Posts Modifications, Alterations and Updates 20 04-23-2003 10:48 AM
