Wheel Weights with Bathroom Scale - Fiberglass RV
Old 05-16-2009, 09:23 PM   #1
Pete Dumbleton's Avatar
Here's a great method of weighing one's small trailer using a bathroom scale and some leverage, posted by one of the Yahoo Scampers.
One change I would make is to call the Gross Weight Total Weight because my understanding is the Gross Weight is only that weight on the axles (Tongue weight being on the tow vehicle), however that may differ between trailer manufacturers; I base my understanding on the fact that the trailer GVWR usually seems to be the same as the GAWR) -- Also, the distances should be measured from the center of the grease cap and there would be more accuracy if the small pivot piece on the left end of A was triangular
With larger trailers, one should be careful to keep A very long in order to not overload the scale.
Old 05-18-2009, 09:58 PM   #2
Roy in TO's Avatar
Thanks Pete,
But shouldn't that be the other way around?
Keep "A" short and "B" long?
Thinking of how a pry bar works, the closer the wheel is to the scale, the more weight it would put onto it.
Old 05-18-2009, 10:18 PM   #3
Here is one I found for tongue weight. Same principle. I think that "B" in Pete's example will be the total distance between the two support points. The idea below is to offset the leverage point to reduce the weight to the range that the scale can handle, then adjust back the correct weight.
http://www.rverscorner.com/tongueweight.html
I tried weighing my tongue to determine the impact of putting weight on the back. I got very inconsistent results so I gave up.
Dave
Dave Fish is offline   Reply With Quote
Old 05-19-2009, 09:36 AM   #4
Trailer: Fiber Stream
That is how it is done in a mechanical scale.
Old 05-19-2009, 04:28 PM   #5
Dan Meyer's Avatar
I understand that gross weight is the total of axle weight plus tongue weight.
-- Dan Meyer
Old 05-19-2009, 11:05 PM   #6
Roy, you're right -- The arm to the scale should be the long one!
Old 05-20-2009, 12:18 PM   #7
For my bathroom scale the ratio would be about 6:1
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Expanded Scale Voltmeter Jeanne and Steve Problem Solving | Owners Helping Owners 9 05-17-2008 02:40 PM
scamp fifth wheel bathroom Paul and Libby Smith Modifications, Alterations and Updates 1 10-26-2007 06:32 AM
Do your pets and kids scale down too? Gina D. General Chat 20 10-09-2007 10:53 PM
5th wheel bathroom water damage Paul and Libby Smith Problem Solving | Owners Helping Owners 2 09-19-2006 06:45 AM
5th wheel front bathroom Legacy Posts Problem Solving | Owners Helping Owners 3 06-28-2003 06:30 PM
