...was wondering which harness connector,4 or 7 point, would be the most suitable to have, should i even have the harness put in before i have a trailer?
The
default wiring harness for most auto manufacturers nowadays is the 4-pin flat connector. If you are looking to get a simple 13' Trailer that does not have
brakes, and you could make do without the "House
Battery Charge Line" this connector would be adaquate. It would activate the Brake
Lights, Turn Signals, and the Running/Side Marker
Lights.
However, if you want Electric
Brakes to function on your trailer, and be able to connect the trailer's
battery to the tow vehicle's alternator/generator/charging system, then you'd need a bigger harness with more connectors. I am not familiar with the
Mitsubishi Delica. Do they have a comparable vehicle
sold in the US under a different name?
I have a 4-pin flat harness "hard-wired" into my tow vehicle's
electrical system. (This was a module provided by
Honda) It plugs into the back of the 7-pin recepticle mounted on the hitch receiver. This recepticle has the Brake Controller Output and the
Battery Charge Line, as well as the Trailer Back-up
Lights hard wired into it.
This gives me [b]both possibilities. If I am towing a small simple trailer, I unplug the 4-pin flat from the back of the 7-pin round recepticle, bypassing it, and plug that directly to the trailer. If I am towing my 16'
Fiber Stream, I go thru the 7-pin round recepticle and have all the circuits activated.
