Why two axles???? - Fiberglass RV
Old 01-24-2013, 03:27 PM   #1
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Why two axles????
I've looked all over the place for an answer to this question without any luck at all, so I thought I'd put it out here:
What is the rationale for putting tandem axles on any of our relatively small trailers instead of a single heavier axle??? Can't be a "redundancy" thing, since the individual axles used in such applications aren't sized to bear all the load on their own, nor are the tires mounted thereon.
It can't be a suspension thing, either (torsion vs. leaf-spring), since I just got finished combing through Dexter's application guidelines (link), and big torsion axles such as the 7,000 pounder can be used singly with properly load-ranged tires.
This question is based on my own aversion to tire maintenance/towing issues related to the use of tandem axles, not the least of which is simply the doubling of tire replacement expense. I'm not criticizing any trailer maker, I'm just curious as to what if any practical "design/performance" reasons exist for their use.
So what's the deal with tandem axle trailers, especially in our "small compared to many trailers" world???
Thanks!
Francesca
Old 01-24-2013, 03:35 PM   #2
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Pros and cons at: RV.Net Open Roads Forum: Travel Trailers: Tandem axle vs single axle
Old 01-24-2013, 03:45 PM   #3
Yes, I saw that thread..., and others like it. Belief in " providing redundancy" seems to be a big theme, and since neither tandem axles nor the tires on them are sized to do that it, it can't be a design parameter.
Any ideas in that department would be greatly appreciated!
Francesca
Old 01-24-2013, 03:46 PM   #4
cpaharley2008's Avatar
The dual axle tows easier and there is less bounce, sway, movement of interior items. They also add a level of safety while on the road to blow outs. That said, they add about 400# of weight and tolls will be triple what a single axle are. Personal preference.
Old 01-24-2013, 03:54 PM   #5
Trailer: '77 Scamp
I'm just glad they do put 2 axles on trailers. I have 2 on my 25' Airstream. It's heavy enough to make sense of 2 axles, but the big advantage for me has been safety. If you have a flat or blowout or broken axle while towing, you still have control of the trailer because the other tire/axle supports the trailer, allowing you to pull over safely without damaging the trailer. Then, you don't even need a jack...just raise the trailer by driving the good tire on the disabled side, onto blocks used for leveling, change out the tire, and you're on your way. I'm a little nervous towing my single axle Scamp for that reason.
Otters is offline   Reply With Quote
Old 01-24-2013, 06:12 PM   #6
David Tilston's Avatar
I always thought the advantage was that it tracked better. But I have absolutely no experience. The only trailer I have ever towed was a Trillium, (not the 5500).
Old 01-24-2013, 07:10 PM   #7
I know that on horse trailers its a safety issue - imagine pulling a single axle on the freeway and having a tire blow out with a horse in the trailer. Giddy up big time!
Old 01-24-2013, 07:20 PM   #8
Merle Lilly supplied a write-up for our Document Center on his dual-axle Scamp 5er. After the modification, the blowouts stopped: Fiberglass RV - Document Center - TandemAxleSetup
Old 01-24-2013, 08:14 PM   #9
IllAnnoy
PRO: Tandem axles can result in less tongue weight as a percentage of trailer weight.
Slightly less prone to sway.
Con: A tandem axle must be towed level enough to evenly distribute the weight on the axles. While that sounds elementary, you can seldom drive a hundred miles on any major highway without seeing an obvious violation of this principle. Tongue too high, loads the rear axle...tongue too low, loads the front axle.
Properly loaded, the tires still scuff on turns.
Old 01-24-2013, 08:43 PM   #10
Trailer: Fiber Stream
I disagree.
I have experienced tire failure with my tandem axle Fiber Stream. With 75% of my tires unaffected, the only way I even knew I had a tire fail was a subtle sound that went tic-tic-tic-tic-tic-tic-tic-tic-tic-tic-tic for about 1/2 mile. There was no change in handling characteristics at all. My passenger and I were in conversation when I stopped and said,"Something doesn't sound right." I pulled over and looked; the trailer's attitude had not changed- it was still level. I got out and looked at each tire; the 4th one counter-clockwise from from my driving position (forward axle, curb side) was blown on the inside side-wall. Very easy to change to the spare and continue on our way.
Old 01-24-2013, 08:50 PM   #11
Interesting...aside from a few per handling differences, most responses so far seem to be consistent with what I read on other user forums: that the main purpose of the second axle is to provide "protection" from- what-deficient tires???
Is it thought that this is a design parameter for trailer makers, and if so, why are there any single axle trailers on the road at all???
Francesca
Old 01-24-2013, 09:38 PM   #12
Mike Magee's Avatar
Trailer: Li'l Hauley
My former 23' Rockwood had tandem torsion axles, and stuff bounced all over the place; I had to do all sorts of tricks to keep drawers and cabinet doors closed. My current trailer has a single spring axle, and it rides so well the stuff inside stays put. Go figure.
How to prepare Tofu
Step 2: grill some meat
Old 01-24-2013, 09:55 PM   #13
Trailer: Casita 17' SD
The Casita I own had lousy tires on it from the factory. I had two blow outs and it was scary. After that I put better tires on and went up a size. That took care of the problem. But the factory kept putting on those crummy Goodyear tires and everyone back in those years complained of blow outs. Now the factory puts on 15 inch tires and it works great as it gives the trailer more ground clearance for off road use. Don't know if this helps about tandem axles though?
Rattlesnake Joe is offline   Reply With Quote
Old 01-24-2013, 10:03 PM   #14
Tandem axles double your maintenance. More tires, brakes, wheel bearings. They also result in more weight and more drag ( tires on surface ).
As for safety, perhaps, but there are reports of drivers beating their wheel wells to death because they weren't aware that they had a flat ( maybe more so with stick built? ).
So why tandem axles? Because people believe four wheels are better than two and that's what the market demands. It's why people use Classic Coke to clean their toilets and remove silicone.
Help for tired axles Lyndon Laney Modifications, Alterations and Updates 15 05-08-2014 05:32 AM
u haul axles h.mike Towing, Hitching, Axles and Running Gear 5 01-21-2012 08:13 AM
al-ko axles Dan B Problem Solving | Owners Helping Owners 2 06-02-2008 10:44 PM
Flexiride Axles Benita Care and Feeding of Molded Fiberglass Trailers 3 09-17-2006 03:12 PM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
