Originally Posted by rileydf
Thanks Brian,
Do you know if there are adapters to go from a flat 4 pin to the 7 pin RV wiring?
Generally the adapters are are to go from a 7 pin on the tow vehicle to a flat 4 on the trailer so one can pull a small utility trailer with a 7 pin equipped tow vehicle.
The 7 pin connector on the tow vehicle will need additional wires for the
brakes and tow charge line, so you may as well tap into the flat four harness.
