***Wiring up boler quick question*** - Fiberglass RV
Old 05-26-2011, 10:10 AM   #1
Trailer: 74 boler
Hi Guys
Installing a 4 way flat wiring harness for lights on the boler. I don't have side markers so it seems pretty straight forward.
Only question I have is this:
On the passenger side rear lights, There are 3 wires coming through into the trailer and only 2 on the drivers side. Is this where the white ground is to be connected?
I am very confused as to where to attach the ground wire, I've wired in the brake lights/running/turn ones hopefully right, but I have no idea where to put this white ground wire to….any help would be great
thenoob is offline   Reply With Quote
Old 05-26-2011, 02:21 PM   #2
Trailer: Fiber Stream
Post
A ground wire "pigtail" may have been pulled of the driver's side fixture; or the tail-light manufacturer never installed one.
Let's use this picture as a guide for your driver's side tail light:
  • The Brake/Turn wire connects to the Bright filament of the dual filament bulb. (I'm guessing it's the black wire.)
  • The Running/Tail wire connects to the Dim filament of the dual filament bulb. (I'm guessing it's the red wire.)
  • The Ground wire connects to the metal base of the light; or one of the two brass mounting screws on either side of the wires.
This would be true for both sides.
You need to check if one of the 3 wires on the passenger side fixture is attached to the metal base.
Old 05-26-2011, 02:32 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Old 05-26-2011, 02:54 PM   #4
White = Ground (You knew that)
Brown = Dim Filament of BOTH Tail Lights
Yellow = Bright Filament of LEFT Tail Light
Green = Bright Filament of RIGHT Tail Light
boler, ground wire, tail lights
Switch wiring question Lawrence W Electrical | Charging, Systems, Solar and Generators 11 09-12-2011 10:48 AM
boler wiring question Rick kl Problem Solving | Owners Helping Owners 1 12-13-2008 02:49 PM
Quick stop question Pat M Care and Feeding of Molded Fiberglass Trailers 7 05-25-2008 04:20 PM
A Quick LED light question Bonnie Problem Solving | Owners Helping Owners 3 11-23-2007 10:10 AM
Quick question for you Oregonians and others Joy A Camping, Campout Reports 7 05-01-2007 07:11 PM
