With new axle, trailer no longer tows level -- concern? - Fiberglass RV
Old 07-26-2016, 05:38 PM   #1
Ellpea in CA's Avatar
The Lil Bigfoot is now 3-4 inches taller than it used to be. So it does tilt down in front to hitch to the Volvo. Is that a concern?
Ellpea in CA
1988 13.5' Lil Bigfoot
2002 Volvo V70 (turbocharged)
5 cylinders, 5 speed auto transmission
Ellpea in CA is offline   Reply With Quote
Old 07-26-2016, 05:45 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Down is better than up, but the fridge won't work as well (if at all) unless the average road ride is fairly level.
Charlie Y
Old 07-26-2016, 06:39 PM   #3
Dudley's Avatar
Trailer: 1998 Casita 17 SD
depending on the receiver, you may be able to remove the ball and flip the receiver to increase the ball height. The other option is a new receiver with the proper height for the trailer
Old 07-26-2016, 06:43 PM   #4
Civilguy's Avatar
Trailer: Sold 2012 Casita FD 17 - 2018 Escape 21 on Order - 2010 Audi Q5
Puget Sound, WA
While level is recommended, "they" say that having the A-frame and coupler tilted a bit downward is preferred to any upward tilt.
I think the most common and economical approach is to simply get a different drawbar to get the ball height properly aligned with the coupler height. Things to consider include maintaining clearance for the hatch to open without interference from the tongue jack, etc.
In my case the tow vehicle manufacturer indicates a very limited range of permissible ball mounting locations. I posted here in regard to my Casita a while back:
Axle Lift Kit & Coupler Height
Glenn said easy-peasy to lowering the coupler. We still haven't gotten together on that. But then, I haven't done the lift yet.
- "Character is what you do when nobody’s looking." -
Old 07-26-2016, 07:17 PM   #5
Mr Lynn's Avatar
Trailer: 2013 Casita Spirit Deluxe 17, purchased from original owners May, 2016
Massachusetts
Terminology alert!
I'm confused about the terms for the components of trailer hitches.
My understanding was that the 'receiver' was the part welded to the tow vehicle with a square female opening.
The part that goes into it is a 'ball mount' or maybe 'insert'. By this account, what Dudley means is to 'flip the insert' (which will give you anything from 0 to maybe 12" difference in ball height, depending on configuration of the insert.
Then there's the term 'stinger', by which I assume is meant the insert, unless it is the 'receiver'—or maybe the 'coupler'—the tongue of the trailer that fits over the ball?
Clarification welcome. Then back to your regularly-scheduled thread.
/Mr Lynn
"The Molded Fiberglass Obsession"—From a Pickup Cap to a Casita
"Hillbilly at Harvard"—Honky-tonk Country and Bluegrass
Mr Lynn is offline   Reply With Quote
Old 07-26-2016, 07:20 PM   #6
IllAnnoy
assuming that the trailer is towed most of the time it is hitched, then the fridge won't be affected. Modern propane fridges are now designed to tolerate 15 degrees off level, a big improvement over years past
Old 07-26-2016, 07:37 PM   #7
minke's Avatar
Trailer: looking
I don't know how much rise or drop your current hitch has. Perhaps one of these can help: 1-1/4 Inch Hitch | etrailer.com
minke is offline   Reply With Quote
Old 07-26-2016, 08:24 PM   #8
Fridge angle
The fridge, as far as I know, is original to the trailer, which is a 1989...? I haven't measured the angle off level yet.
Ellpea in CA
Old 07-27-2016, 10:17 PM   #9
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
the part you call a receiver is actually a ball mount, or drawbar.
the receiver is the part bolted to the car.
The refrigerator can stand more off level that you think.
Old 07-28-2016, 03:48 AM   #10
Raz
Raz's Avatar
Vermont
As suggested, you can raise the tongue by changing the draw bar which will change the ball height. You also need to make sure it is far enough back so as not to interfere with opening the rear hatch.
Old 07-28-2016, 04:08 AM   #11
Trailer: Escape
I read somewhere in my fridge manual that level was only important when the trailer was parked. When on the road the swaying action of driving negated the need for the fridge to be level.
Sunrisetrucker is offline   Reply With Quote
Old 07-28-2016, 05:39 AM   #12
Ohio
Tow as level as possible, then, you have no worries.
cmartin748 is offline   Reply With Quote
Old 07-28-2016, 09:11 AM   #13
Trailer: U Hall VT
Just flip the insert over and see if that levels it out, or get one that will make it level.
Roger Kimble is offline   Reply With Quote
axle
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
Generator exhaust concern on trailer tongue. Kevin K Problem Solving | Owners Helping Owners 82 02-25-2014 06:11 PM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
