Yellow wire on 7 pin connector ? - Fiberglass RV
Old 04-12-2008, 07:39 PM   #1
Trailer: 13 ft Scamp
Can anyone tell me the funtion of the seperate 10ga yellow wire on a 4-7 pin adapter ? The 4 wire plug receptacle plugs into the Subaru harnees, the 10ga black goes to the battery for charging, the 10Ga white is a ground, the 10ga blue goes to the brake controller, but I don't know what to do with the 10ga yellow wire on the 4-7 pin adaptor. Should I leave this disconnected ?
Mikeny is offline   Reply With Quote
Old 04-12-2008, 08:15 PM   #2
Trailer: Fiber Stream
Talking
The most common use for the yellow wire is to activate Back-up lights on the trailer. I had to dig into my Honda Odyssey's harness in the left quarter-panel to find the supply wire.
If your trailer does not have back-up lights, or you don't want to bother with them, leave it disconnected.
Old 04-13-2008, 01:22 PM   #3
Pete Dumbleton's Avatar
Umm, be careful using colors on trailer wiring because THEY DIFFER between connector types. Compare colors for 7-pin and 4-pin in this common chart:
http://www.marksrv.com/wiring.htm
You can see that yellow is Aux/Backup on the 7-pin, but is LeftTurn/Brakes on the 4-pin.
You can wire the 'yellow' as conventional backup, or put a special garden tractor flood lamp on trailer bumper as camp site backup (special switch in TV) or connect a sprayer to go with your "Follow Too Close and I'll Flush!" bumper sticker
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Towing, Hitching, Axles and Running Gear 5 04-20-2008 02:11 PM
What is the yellow wire? Victor Benz Problem Solving | Owners Helping Owners 15 06-29-2006 01:30 PM
Yellow dog Legacy Posts Jokes, Stories & Tall Tales 5 09-21-2002 02:16 PM
Yellow wire on 7 pin connector ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
