NC Oct. 11-13, 2012 Fall Rally in Cherokee NC - Page 13 - Fiberglass RV
Old 11-28-2012, 07:13 PM   #169
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Originally Posted by Jane SC View Post
Don, what did you use for your power supply? The TV is 12 V, did you use the light power that powers the light? Or did you fish the TV plug down the side? I assume you put the power cord and cable thru the top. The curtains and bed spread are free, just pay the postage. Greg
Mr. Greg,
I used a 12 volt cord with an end identical to what was supplied with the adapter. (This way I still have the original adapter in case I ever wanted to use it with AC.) I wired it downwards to a power supply below. I had previously installed a 12V marine AM/FM/CD/MP3 player under the sink so I just wired it into that same circuit. I also have a toggle switch to cut off all power supply to the tv and radio when not using the camper for longer periods. I attached the 12v cable to the antenna cable with small cable ties and they feed into the same hole that is located just below the wall bracket.
Thanks Indeed for the curtain offer!!! I'll PM you now. Your PM came thru OK on your last attempt...
don '85 CT-13 PEACE be with you!
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
Old 11-29-2012, 04:36 AM   #170
Jane SC's Avatar
Name: Jane and Greg
Trailer: 1985 Uhaul CT
South Carolina
Don, thanks. I came up with another solution. I purchased a under-cabinet tv mount from Best Buy. (rocketfish RF-TVMUCO1 ,13-22 ") . I did not want to deal with mounting on side of camper. Yesterday I moved the counter light to the center /over stove and sink. Looks better in the center too. I fished the cable thru the wall as well as a short extension cord to the power below. TODAY I will mount the bracket....can not wait for the sun to come up! First I will fit a 1/4 inch 11 by 8 piece of plywood inside the cabinet for support...and see how it goes...the bracket also has a 45 degree swivel! Isn"t this fun? Will send photos. Greg
Jane SC is offline   Reply With Quote
Old 11-29-2012, 02:48 PM   #171
djtriceflt's Avatar
Thumbs up
Mr. Gary,
Yes sir, about the fun!!!
I sent a PM.
fall, rally
OR | Oct 11-14, 2012: Fall NOG - Northern Oregon Gathering Donna D. Rallies, Get-togethers, Molded Meets (Archive) 87 06-28-2013 11:52 AM
PA | Oct 26-28, 2012: Fall / Halloween Egg Rally, in central Pa. cpaharley2008 Rallies, Get-togethers, Molded Meets (Archive) 56 11-09-2012 11:30 AM
IL | Oct 19-22, 2011: Fall on the Mississippi Rally DENNIS ARCHER Rallies, Get-togethers, Molded Meets (Archive) 14 11-21-2011 09:09 AM
NC | OCT 13-16,2011:Fall Rally in Cherokee NC CindyJ Rallies, Get-togethers, Molded Meets (Archive) 79 10-21-2011 07:09 AM
Fall Rally in Cherokee, NC Oct 21 - 24, 2010 TomP Rallies, Get-togethers, Molded Meets (Archive) 32 10-29-2010 04:52 AM
