Originally Posted by Stacie Tamaki
Any chance you know the weight and dimensions (particularly height) offhand? I've been looking for a Minit because my tow vehicle is only rated for 1000 lbs and read elsewhere online the Compact II may weigh less than that as well.
Stacie if you havent already found it there is a list of
Trailer Weights in the Real World on this forum. These were trailers weighed at trailer meets with peoples belongings in them. You should expect any trailer you buy to weigh in at 500/600lbs more than the manufactures dry weight. Reason for that is the dry weight does not include things such as
battery,
propane tanks, fridges, awnings etc. and add to that your own belongings. Compact II's listed range in weight from 1720lbs to 2020lbs.
