Bed, tire cover & filler - Page 2 - Fiberglass RV
Old 05-31-2006, 03:27 PM   #15
Trailer: 1981 13 ft Scamp
Hello Munsons....
Yes, please bring the two burner stove, along with the gocho bunk-bed. I'd like to have them both. My gocho bunk bed was so rotted, that I took it out. It's working fine without it, but now that I have a chance to replace it, I'd love to do that. I'll be at Bandon also, space A-47, July 12th and leaving the 17th. Please confirm if I can have these, and the cost. See you in July...I'm getting so anxious. Chari
Chari,
I'll bring to Branson : Choclate Suburban stove & upper bunk bed. Do want the little crescent shaped (brown plaid) filler that goes between the front wall and the bottom mattress?
Jim Munson
shirley munson is offline
Old 05-31-2006, 03:31 PM   #16
Hello Munsons....
Chari,
I'll bring to Brandon : Choclate Suburban stove & upper bunk bed. Do want the little crescent shaped (brown plaid) filler that goes between the front wall and the bottom mattress?
Jim Munson
p.s. no charge
Old 05-31-2006, 06:15 PM   #17
Trailer: Perris Pacer 1979
Chari,
Jim Munson
Hello Munsons again....
Please, I hope your coming to Bandon, Oregon...because I can't make it to Branson, in Missouri. And, yes, bring anything that goes with the goucho bunk bed. Does it have the legs on the bottom of the bunk bed board for support? And yes, the crescent shaped filler too. Did this also come with a narrow board that connected the goucho bed to the wall of the fiberglass? Do you know what I mean? If not, maybe I could use yours to measure to make one for my trailer. My old hinged board crumbled apart pulling it home, so I just took it out, covered the attaching holes of the fiberglass with cauking, and used overstuffed pillows for the back. But, it would be so nice to have it the way it used to be. And Eric, who has a Perris Pacer as well, has his goucho bed in his trailer, and I could measure his bunk bed support board. By the way, where will you be located at Bandon, what is your space number? When will you be arriving? Were you at Bandon last year, 2005? Must go now, but am glad I'm on the receiving end of the goucho bed and the 2-
burner stove. AND, please confirm that your coming to Bandon, OREGON. Good night and sleep tight. Thanks so much. Chari
Chari Benckendorf is offline
Old 05-31-2006, 11:09 PM   #18
I wouldn't be caught dead in Branson. See you in Bandon OR. The upper bunk bed is supported by two pipe posts which I have to keep to support my new counter/workshelf. These shouln't be too hard to duplicate. The wood strip that holds the hinges for the bed should be fairly easy to copy -trace mine if you want. I will be there( 1st timer) the 14th-17th. Site C61.
Glad someone can use this stuff.
Jim Munson
1 upper bunk bed.2 stove.3 filler piece.
Old 06-01-2006, 01:57 PM   #19
Jim Munson
Hello Munsons again and again...
Thanks so much for the goucho bed and it's supplies, and the stove.
This is my second year, and I wouldn't miss the Oregon Gathering for the world.
I've been to the Norther Oregeon gathering (a spinoff of the Oregon Gathering) as well, twice, and...I hope you find as I have, that this is a fantastic group of people. I'm looking forward to meeting you, and becoming good friends. Take care both of you, and I'll see you in July...in Bandon, OREGON. Your friend, Chari
Spare Tire Cover Tom U Modifications, Alterations and Updates 33 01-01-2015 11:20 AM
Spare Tire Cover David and Nancy Modifications, Alterations and Updates 4 05-18-2009 10:07 PM
Spare Tire Cover Terry F Care and Feeding of Molded Fiberglass Trailers 17 09-05-2006 09:11 PM
Dis-colored tire cover Gary Little Problem Solving | Owners Helping Owners 5 05-10-2006 01:31 PM
New Tire Cover Legacy Posts Modifications, Alterations and Updates 2 11-10-2002 02:42 PM
