Black M92 Marr Marrette for Trillium - Fiberglass RV
Old 05-17-2011, 04:00 PM   #1
Rodre's Avatar
Trailer: 1978 Trillium 1300
Hello,
Looks like I am missing one of the black marrette caps that go on the wire joins. It looks like the one in the picture. If anyone has one around from re-doing their wiring, or know where I can get one it would be much appreciated. Thanks!
~Rodre
Rodre is offline
Old 05-17-2011, 05:49 PM   #2
Doug Arthurs's Avatar
any home building centre or hardware store will carry marrettes
Doug Arthurs is offline
Old 05-17-2011, 06:17 PM   #3
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Are those a Canadian thing?
Greg H is offline
Old 05-18-2011, 11:23 AM   #4
Rodre's Avatar
Yes, the Marr company is Canadian you can read their history here:
http://www.tnb-canada.com/en/catalog..._marrcat_e.pdf
I found the missing cap deep in the floor boards of my Trillium, so I no longer need one.
BTW, the model is a No.2, not an M92. The reference one I was looking at the cap was a little beat up and my eyes are getting old - damn.
Here is also some more info on the unit:
Cheers!
Rodre is offline
Old 05-18-2011, 12:58 PM   #5
Greg H's Avatar
Indiana
Ok, I never heard of it and don't have a clue what it does.
Greg H is offline
Old 05-18-2011, 02:11 PM   #6
Rodre's Avatar
Hi Greg,
It is used to join two or possibly more (up to what the metal "barrel" piece will accomodate inside it) electrical wires together instead of a crimp style terminator cap. The nice thing about them is that they are completely reuseable as they have a screw that presses down and holds the wires together from the side, then you simply screw on the black plastic piece (that I was missing) onto the top of the metal barrel piece that is holding the wires together to insulate the new connection(s). You can try and reuse the crimp on ones but it take some patience and skill to open them up again where they will release the wires and so that you can do whatever you need to do then crimp them back on, assuming removing the crimp on terminator didn't damage the plastic beyond being useful. I hate having to cut the wires to get the terminating cap off because each time it gets shorter and shorter. This may not be a problem but in the case of the 7 way cable they only left about 2 inches of cable to work with, so if you have to cut it each time it wouldn't last long and it makes it hard to work with each time it gets shorter.
~Rod
Rodre is offline
Old 05-18-2011, 03:39 PM   #7
Greg H's Avatar
Indiana
Thanks for the info, that's a good idea because I know all about cutting wires and replacing the crimp connecters.
Greg H is offline
Old 05-28-2011, 06:11 AM   #8
Joe MacDonald's Avatar
this style has largely been given up, most people (tradesmen) now use either twist on Marrettes or Ideal twist on wire nuts
Joe MacDonald is offline
Old 05-28-2011, 01:42 PM   #9
Rodre's Avatar
Actually, Home Depot still sells these:
Marrette - Marrette No. 2 Set Screw - Pack of 3 - 2C-CDN - Home Depot Canada
I think they are good for applications where there is a lot of vibrations, such as the trailer rolling down the highway, due to the setting screw that gets locked down by the cap. You could use the crimp on type, but personally I prefer not to for reasons stated above. Just providing this as information for anyone else that may be looking for some and not trying to "be right" or anything like that. Cheers!
~Rodre
Rodre is offline
Old 06-02-2011, 10:28 AM   #10
Just like milk in a bag..... It's a Canadian thing
Paul Riehl is offline
Old 06-25-2011, 01:01 PM   #11
Roger C H's Avatar
Smile Never too old to learn
I don't recall ever hearing of Marrette Caps and I have an associate degree in electic power and worked 22 years designing tools which used such things.
But, then again, we used what our company stocked for the most part.
Makes perfect sense for high vibration applications.
Thomas & Betts makes them:
Thomas & Betts | Search Engine=
Roger C H is offline
trillium
Frames - why black? Andrew GPSMapNut General Chat 19 01-22-2011 11:17 AM
Black tap??? Rick Harmer Problem Solving | Owners Helping Owners 1 01-22-2010 04:19 PM
Use the Grey in the Black? Tamid Modifications, Alterations and Updates 10 04-15-2009 09:22 PM
Black bear Morgan General Chat 9 05-19-2006 12:39 AM
Black streaks Chris Z Care and Feeding of Molded Fiberglass Trailers 5 12-07-2005 07:40 AM
