Dometic Catalina Awning Wand Needed - Fiberglass RV
Old 11-06-2009, 08:49 AM   #1
Trailer: Scamp Custom Deluxe 19 ft 5th Wheel
Virginia
My Casita has a Dometic Catalina 2500 awning. I have not opened it yet, looking for the wand. Is there a wand inside the awning housing somewhere? Is it something I can make from a screwdriver, etc. Please share your knowledge -
I downloaded the installation/operation manual. Thanks. Maureen S
Maureen S is offline
Old 11-06-2009, 11:28 AM   #2
Trailer: 2008 13 ft Scamp
I don't even use the wand; a metal tent peg with curved end works fine, assuming you're tall enough. Stick the sharp end of the peg into each leg piece to slide them outward from their locked position, then use the curved end of the peg to snag the cloth loop and pull. Again, if you're tall enough, you can grab the loop with you hands and pull. It's not that hard.
Jeff
WI
Jeff Peterson is offline
Old 11-06-2009, 05:40 PM   #3
IllAnnoy
A philips screwdriver works great if yo can reach it, I have a Scamp 13, so I just use my fingers. I gave away my awning stick or i'd love to give it to you.
The original was a steel role-pin in the end of an aluminum extrusion.
A piece of 1/2" thinwall conduit with a 5/16" bolt welded into the end would make a nice one, and even lighter than the original!
Or you could find a mid-sized philips screwdriver with a shaft large enough and a handle small enough and simply shove the handle into a 2-3 ft piece of 1/2"or3/4" thinwall and drill a screw into the side to secure it!
floyd is online now
Old 11-07-2009, 04:06 PM   #4
Virginia
Thank you both very much. I appreciate your responses. Maureen S
Catalina 2500 Awning Elizabeth Schneider Classified Archives 4 10-03-2009 01:21 PM
Catalina Awning replacement Don A. Problem Solving | Owners Helping Owners 5 09-11-2009 12:31 PM
Trillium Dometic RM 211 Fridge Up-Grade Info Needed Josh Henderson Problem Solving | Owners Helping Owners 2 10-30-2006 05:10 AM
Awning Support Leg needed llollio Care and Feeding of Molded Fiberglass Trailers 7 06-04-2006 12:21 AM
Dometic parts needed Sharon Herman Problem Solving | Owners Helping Owners 1 11-15-2005 12:12 AM
