Four Head, LED Under-Cabinet Lights - Fiberglass RV
Go Back   Fiberglass RV > Marketplace > Classified Archives
Click Here to Login
Old 10-18-2013, 08:00 AM   #1
ShawnKK's Avatar
These are the same brand as seen at Home Depot and Bed Bath & Beyond and many other stores but for a lot more money. Harbor Freight has them on sale for 9.99 and if you use the 20% coupon if your store will let you it comes to 7.99 each. These lights use 6 AAA batteries but you can wire them to 12 volts with a converter.
If you want to wire them up to your 12 volt system you can use a 12v to 5v converter or HF has the Universal USB 12 Volt Adapter for 4.99.
Each adjustable head on this handy under-cabinet light includes 3 white LEDs that last up to 100,000 hours each! The under-cabinet light is battery-operated so there’s no wiring or installation required. Brighten up dark corners and dim areas with this handy track light, great for cabinets as well as bookshelves, offices, kitchens and more!
  • Track lighting to be used under cabinets
  • 12 bright, white LED bulbs that will never burn out
  • Four light heads, each with three LED bulbs
  • Battery operated -- no wires or installation required
  • Light heads swivel for perfect adjustment
Don't forget to get the freebies! Each store has a coupon book as you walk in with freebies. Ex Flashlights,multimeter ect ect ect
ShawnKK is offline
light, lights
Trillium Interior Reno - O/head cabinet sliding doors peatle Modifications, Alterations and Updates 13 05-19-2019 01:40 PM
Ikea under cabinet lights courtney Modifications, Alterations and Updates 1 06-20-2013 02:12 PM
LED Lights Roger C H Modifications, Alterations and Updates 8 02-04-2012 08:20 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
