If you own a mini van or small SUV, this is the trailer for you. We are the 3rd owner of this well maintained unit. Previous owner towed it with a Dodge Caravan and we towed it with a Honda Odyssey. What will you tow it with?
Bigfoot B19 19' Travel Trailer has an approx 2600lb (net/dry) w/ 3250 Gross
Weight. Dual axles have been flipped over for better clearance. Tows like a dream (doesn't sway) with an average sized V-6. 4 wheel breaks and bearings serviced in 2006.
It will sleep 4 (or 5), 2 @ the Front Dinette and 2 @ the side gaucho (pull out couch). The storage cupboard above the gaucho has loads of room, and folds out into a bunk that would sleep a youth.
There are large storage cupboards at the back, and a 3 Piece bath (Toilet, Sink, FG Molded Shower)
4 burner stove w/ oven with range hood, fan and
light. Double SS sink w/ on demand water pump and upgraded
lights through out and the 'Fantastic Fan' provides great ventilation (next best thing to an AC)
A 2004
Solar panel w/ display keeps the single
battery charged indefinitely. It is wired for a 2nd. 30 amp service line into a converter provide constant power and there are 2 (or 3?) 120 outlets inside, plus a aux. 12v power outlet, most interior
lights updated in 2005.
2002 Hot water tank, new 50' water hose, Electric/Propane
fridge, 2005
Furnace, TV Antenna w/ booster, 2X20lb
propane tanks w/ switch, Full length
awning, includes real simulated grass for under the
awning.
Lots of original documentation for trailer and equipment
with hitch and EQ bars and extension mirrors.
$12,500 obo for everything.
