AB SOLD: 1976 Trillium $3500 OBO - Fiberglass RV
Old 04-27-2014, 11:12 PM   #1
1976 Trillium Fiberglass Trailer
Located Edmonton, AB T5G 0Z6
Very lightweight, can be towed with just about anything.
Structurally in good shape, no cracks in fiberglass or frame.
All original appliances.
Inside lights all functional.
3 way fridge (12V, 110V, Propane). Works for sure on 110V, doesn't cool as well on propane, can't confirm about 12V.
2 Burner Stove - works great
Furnace - works great
Inverter - Never used so can't confirm condition
Missing rock guard from the front window.
Windows are original, all cranks working.
The windows need to be re-sealed, some moisture in the mornings after a heavy rain.
New tires and rims purchased last year, maybe 200 km on them. New spare included as well.
The previous owner painted (non-professionally) both outside (white) and inside (blue). I was planning to clean this off, but have not had time.
Totally functional, would be beautiful with a little TLC. $3500 obo.
Kijiji Link
Dennis_S is offline
Old 04-28-2014, 11:51 AM   #2
David Tilston's Avatar
It is not an inverter. It is a converter, (120VAC to 12VDC). To test it, plug in the trailer, if the lights turn on with no battery, or tow vehicle, it works. You may have to play with the switch on the front. It has three positions. In one position, the battery powers the lights, in the middle, all 12VDC is off, in the other position the converter powers the lights. I made the same mistake. The receptacle in the front makes it look like an inverter.
The fact that the fridge cools well on 110 VAC means that the fridge is good. The gas fittings may have spider webs, and just need to be cleaned.
This is a very good price for this trailer.
David Tilston is offline
Old 04-28-2014, 09:05 PM   #3
Thanks for the correction on the inverter/convertor.
I did test it plugged in to my garage and the lights worked. No battery to test it and only a 4 pin wiring harness from the trailer. Previous owner did a few "mods".
I did pass on the information about the fridge to the new owners.
It is now sold.
Dennis_S is offline
trillium
On (Canada) - 1976 - Trillium 1300 - $3500 David Tilston Referrals: Molded Fiberglass Trailers 4 08-06-2013 06:57 PM
BC | 1976 Trillium 1300 $4725 OBO-sold gmcgilli66 Classified Archives 14 11-24-2012 04:41 PM
CANADA - 1976 Trillium 1300 Front WC - $3500 David Tilston Referrals: Molded Fiberglass Trailers 0 10-01-2012 04:27 PM
13' Trillium Trailer 1976 - $3500 Red-Dwarf Referrals: Molded Fiberglass Trailers 5 02-10-2012 06:16 AM
SOLD - 1976 Trillium 1300, $3500 Raya Classified Archives 47 11-30-2008 11:57 AM
