This is a one owner, 2010 16’
Scamp in excellent condition with tons of upgrades! The floorplan is layout #4. I traveled extensively in the trailer, and soon realized that all the provisions to accommodate multiple people were taking up room needlessly. This trailer has been optimized for the solo traveler, but can sleep one additional person. I also realized that many of the factory items, like the cheap Suburban
furnace and the dinky 13” wheels had to go, along with a pile of other stuff. There are MANY hours of work in this trailer. Now it really works! It has extensive
electrical upgrades. It has been very well maintained, and fully serviced. Everything works well. Ready to leave today. If you spend a good bit of time traveling, you will really appreciate this gem. It has been off the road in storage for the last 3 years. $13,900
Contact David in Prescott, AZ
daskinetic@gmail.com, phone/text 541-808-7482
Upgrades:
14”
tires and wheels > tows much smoother with more ground clearance.
14” spare tire and new cover > had to upgrade the spare tire holder too.
Rear hitch receiver > accepts bicycle carrier, etc
High / Low
tail lights > prevents bicycle from blocking
lights
Aux back-up
lights > throws a flood of
light for backing up in tight spots
Swing up hitch jack > no more dragging the hitch jack,..maximum clearance
Rear leveling jacks
Greaseable hubs > easy hub maintenance
Electric
brakes > safer towing, especially on ice
30 pound
propane tank
Brand new oversized
battery, 129 AH
Upgraded Atwood Everest
furnace > finally a quiet nights sleep! More efficient
Electronic thermostat > maintains steady temperature,.. no more hot / cold cycles
High rise bar faucet > now you can actually get things under the faucet
Super quiet range hood > Cook inside without smoke and grease everywhere
Fantastic fan and large
escape hatch in roof
Lots of extra custom built storage inside
Upgraded wood cabinet doors
Grey water tank and sink
12 gallon fresh water tank
Flojet Quiet Quad water pump > no more wild pulsing, smooth and quiet
Paddle latch with deadbolt on entry door > smooth operation and secure
Bi-fold screen door
Heavy duty shore power cord with marine bayonet connection
Inteli-Power 9100
battery charger > charge the
battery from shore power
Charge wizard battery management > prevents battery sulfation
Xantrex link 20 battery monitor > accurate measurement of battery condition and charge
Aims Power 800w max invertor > run 120V AC items from the battery
Dual 12V power outlets > accepts 12v accessory plugs
Standard 120v AC outlet > plug in 120V AC items when on shore power, like electric heaters
And more.........
