This
Casita is as beautiful as a brand new one that has been "slightly used and in easy used condition, it has been well taken care of, never been smoked in, no pets, and I believe I'm the first to really use it. The stove is not even darkened on the burners. The interior is all original and does not look used.This 1996 liberty deluxe as I understand it, is the only model ever made that makes into 3 different bed configurations so that it can be arranged to 2 single beds or 1 double or 1 king. The
Casita is fully self contained, absolutely nothing wrong with this trailer. The prior owner installed some beautiful tile behind the sink and stove, he was a builder so it looks professionally done and adds a bit of color to the unit. I have tweeked a few things. I added a drop down bracket to hold a TV, which is in the corner where there's a 12V plug or
electrical outlet so you can buy a tv that runs off ac or cd current. I added 4
electrical outlets (2 was just not enough) I left all the 12 volt
lights that are mounted under the cabinets, but changed the bulbs to LED, and I added LED strip
lighting that is on a continuous roll that runs above the cabinet and below the cabinets. They turn on and off, as well as dim, Chase, flash and run all with a remote. It can be as bright as a landing strip, or dimmed for mood
lighting. I have installed a
microwave which is above the 3 way
refrigerator, with a drop down door that is used as a little work area. I have added tinting to the
windows to cut down on the UV Rays, and sunlight. It has mini blinds. I replaced the outside water spigot, and the first of August had the entire toilet taken out, system cleaned and the toilet resealed and reseated. I added some storage baskets to the walls in the bathroom along with an accordion mirror that has one side as 20x magnification. I have installed the heat strip on the roof mounted interior A/C unit to allow a choice between
propane heat, or electric heat. I have installed a Hott Rod to the water heater to have continuous electric heated water flow as well as a cut off switch should you ever want it off, (really there's never a reason for it to be off, it only works on electricity, and that usually means you are connected to a hose, so why would you not want continuous hot water for those long showers) or you still have the option of
propane water heating and the stove does require
propane to cook. I have replaced all outside yellowed plastic pieces; vents, vent covers, stove vent, etc. all the rivet snap covers have been replaced as well. I added shelving to the closet along with a mounted safe for your valuables and you can put in your own code. The "casita" decals were not on the unit when I got it, so I ordered the them from the factory and I installed them. The unit did not have a pull out step, so I ordered one and installed that. I have added the plastic cover over the propane tanks as well as a "easy change kit" on the propane so you don't have to get out a crescent wrench to change bottles, you just turn a dial and your pulling off the other tank. I Painted all the frame to a fresh black
paint job. I have added a platform to the back of the unit. It was professionally welded to the frame, which makes it permanent unless cut off with a welding torch. The platform holds the suitcase "Powerhouse"
generator that will power the entire unit for 3-4 hours. It's very low noise, however it is Not included in the sale. The
generator is remote start, or electric key start or pull cord start. If you want this one it has less than 10 hours on it and I'll sell it to you for $700. (New is a 1000$) The
fiberglass shell on the
Casita is in excellent condition, it has been treated well through out the years, since I have had it I have put on a product to bring it to even a higher gloss, and buffed to a like new appearance. The wheel bearings were just recently checked and greased. There are no
leaks, no soft spots and no damage, never had any, so no repairs have been done. This this is like new all original. All maintenance it up to date on this unit, you will not find one in this great of condition for this kind of money. If you know anything about Casita's they hold their value very well. The casita clubs and Rally's are a blast. There's a whole community of full time Casita travelers. It does come with the anti away kit as well. I pull it 80 mph behind my 4Runner and I never know its behind me. I was going to add a
awning in the future and outside LED
lighting to be under the canopy to
light up the outside seating area at a campsite. It too would be remote controlled with all the options the inside lighting has. As of now, before the Canopy is added, and before the outside LED lighting is added the price is $9995 and I do have a clear
title in hand.
I will send you pictures
