NS TripleE 14' 1977 (Trillium, Boler) - Fiberglass RV
Old 03-31-2011, 11:36 AM   #1
Trailer: Triple E Surfside
Nova Scotia
Triple E TM14 travel trailer, Surfside 1977, 1400lbs
$5,999 Enfield, near Halifax, Nova Scotia, Canada
Photos and email:
PerfectPhoto.CA | Private203
Your 4-Cylinder vehicle can probably tow this VERY lightweight under 1400 lb travel trailer. (GVW 1650 lb / 750KG). Uses the simple 4-wire trailer connector and no electric brakes are required.
* The Triple E, TM14 Surfside is a classic fibreglass trailer from 1977. Similar to its Trillium relative, they just keep on going, and going... At 14 feet it is a lot bigger and nicer than the Boler alternative.
* Very suitable for "off grid" camping using the 12-Volt battery & dual Propane tanks, with onboard water bottle, or plugged in to 120V and water at campgrounds. I installed 12 Volt florescent lamps to help extend battery use time when off grid.
* The large refrigerator and freezer actually came from a VW van, and runs on propane or 120V.
* Includes a carbon monoxide - smoke detector, spare tire, rear piggy-back storage box, and a chemical type porta-potty.
* HEATER: When on 120VAC its easy to heat using those small ceramic heaters that the hardware stores sell. Last year I installed a new propane Catalytic heater, but I am going to remove it, unless you want to purchase it for $350 extra. It is an Olympian Wave 3. These are very quiet since there is no fan involved. I can leave the hookups there if you want to get your own.
* SOLAR PANELS: There are three solar panels installed (45 Watts) which I will remove, unless you want to purchase them for an extra $300. These are used to charge the 12V battery for extended off grid camping. I will also remove the solar panel controll panel (see photo), and cover up the hole with a cover plate.
I love this little trailer, but we are now moving up to a bigger unit.
Its has served me well, travelling all through Atlantic Canada for the past 5 years.
Yes, the first photo is an actual photo of the trailer. I photoshopped it into a nicer background. (I am a photographer)
PS: The vanGO name which is in the pictures is my Geocaching handle. This vinyl label will be removed too.
Rob vanNostrand is offline
boler, trillium
Our 1977 Trillium is on its way! Melanie General Chat 28 07-12-2011 09:16 PM
NS | TripleE 14' 1977 (Trillium, Boler), new price Rob vanNostrand Classified Archives 3 06-03-2011 03:01 PM
1977 Trillium Randy Bishop Referrals: Molded Fiberglass Trailers 1 04-03-2011 09:20 AM
Trillium 13' 1977? for sale debbyj Classified Archives 3 09-05-2008 08:36 AM
1977 Trillium Legacy Posts Modifications, Alterations and Updates 2 10-09-2002 08:07 PM
