Wanted- Solid Rear Window for Uhaul 13' - Fiberglass RV
Old 09-24-2008, 08:03 AM   #1
Trailer: 1984 Burro 13 ft
I am looking to replace my 13' Burro slider window with a solid one.
AdamB is offline
Old 09-24-2008, 08:35 AM   #2
Carolyn Patterson's Avatar
Trailer: 16 ft U-Haul VT / 2004 GMC Safari
Good Luck Adam!
Unless you happen on a complete parts trailer, you'll probably have to either fix what you have or go with a plexiglass window.
My rear window is half glass half plexiglass - the previous owners removed all the windows, resealed and reinstalled but 1 of the sliders in the back was cracked so they had to replace with thick plexiglass. It works perfectly, except none of my windows open!! They're all sealed shut. I have a 'mystery leak' but it's not in that window, it's in the emergency window - somewhere in the exterior rubber gasket - I just can't find it. Yet it only leaks ever-so-slightly when we have a driving hard rain beating on the non-door side (street side) of the trailer.
Just sharing...
Carolyn Patterson is offline
Old 09-24-2008, 08:55 AM   #3
Trailer: 1960 28 ft Airstream
Can I have your slider window?? We had no rear window, so we took plexiglass from Home Depot, and cut it to fit. As it was a snug fit, we placed the gasket against it and pressed it into place. It was a relatively easy fix. It is a solid one.
Pamela H is offline
u-haul, uhaul
Wanted: 1984 Trillium Rear Emergency Window Jessie, K Classified Archives 0 05-31-2010 08:22 PM
Burro / Uhaul 13' Rear Window AdamB Problem Solving | Owners Helping Owners 2 09-24-2008 08:46 PM
Where to get new fr/rear window rubber Brian Scott Care and Feeding of Molded Fiberglass Trailers 0 03-03-2008 03:42 PM
FOUND - Wanted : Rear side sliding window for Scamp DanPatWork Classified Archives 1 08-08-2007 08:34 PM
Replacing rear window Sandra Lair Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
