canoeing with a scamp - Fiberglass RV
Old 06-05-2015, 01:13 PM   #1
Trailer: currently shopping for a Scamp
Hi. We are purchasing a new 13" Scamp and want to know how long a canoe will fit on top of our tow, a 2002 4 cyl. Toyota Tacoma, and still be a comfortable fit for towing, turns, etc. Any canoers out there?
Faith
PatchWork is offline   Reply With Quote
Old 06-05-2015, 01:19 PM   #2
Dennis mn's Avatar
Faith
My Tacoma was a 2003 quad cab. The fifth wheel scamp limited the hauling of a canoe, but a 16' old town is shorter than the truck. It should not interfere with towing your bumper hitch trailer.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 06-05-2015, 01:20 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
Simulate the length of the canoe with something (like a couple of long 2x2s nailed together or one 20 ft length of PVC pipe) on top of your tow. I think the length of the Casita tongue from the hitch/ball to the shell is 3 ft.
Some TACOs are longer then others, mine is a 4door with a 6 ft bed.
Charlie Y
Charlie Y
Old 06-05-2015, 02:23 PM   #4
Dennis mn's Avatar
Charlie Y
Your truck is newer than a 2002 or as mine was, a 2003. They did not have an available long box quad cab for the previous generation.
And mine was a four door with a five foot bed; mine was the same length as the club cab style with a 6' bed, so mine was as short as it gets. I think my truck was 19' overall. I hauled a canoe so that the front was about 9" in front of the front bumper, and used the tiedowns at the front of the bed to lash the back of the canoe. I know that I would not have had an issue with a regular trailer of any type.
Old 06-05-2015, 02:56 PM   #5
Trailer: Escape 5.0 TA
W. Mass
Do you have a cap or a rack for the canoe? You should be able to go about 2' off the back of the truck and as far forward as you're comfortable with. When I had my Ford Rangers (with a cap) and my Starcraft trailer I would carry from 12' to 17' and had room to spare. It all depends on how you want to carry it. If you want to carry it in the bed of the truck, add 2' to the bed length.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 06-05-2015, 03:42 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
Don't go canoeing with a Scamp, you'll ruin the plywood floor.
How to prepare Tofu
Step 2: grill some meat
Old 06-05-2015, 04:34 PM   #7
I was thinking more like a Scamp on top of the canoe might be kind of tippy.
I can add that I put bikes between the back of my Pathfinder and my 13' Scamp and you have close to 2 feet but that may be even less than that when the rear wheel of your truck goes into a dip. The higher the canoe the closer the trailer gets.
Old 06-05-2015, 05:51 PM   #8
W. Mass
Outriggers
Bob & Deb
Old 06-05-2015, 05:53 PM   #9
Dennis mn's Avatar
Actually, unless you have a square stern canoe, turning is not an issue. If the canoe were long enough to touch your trailer when going straight, it will only get farther away when turning. Think about the geometry!
The interference issue would be going over dips!
Old 06-05-2015, 06:26 PM   #10
Not the same vehicle or trailer, but I carry a 16' canoe on my RAV4 without a problem.
You don't say what cab your Tacoma has. You want to have both racks on the cab, or have both racks on the bed so that the canoe isn't twisted with the cab leaning one way and the bed the other on rutted roads.
Pic shows position on RAV, even though it's not connected to the trailer in pic.
Old 06-05-2015, 08:26 PM   #11
Saskatchewan
We tow our Trillium with a Honda Element. I just checked with my guy and he said our canoe is a 17 ft with the end squared off for an outboard (we use an electric one). No problems- can also fit a small kayak on top at the same time. The inflatable goes in the back of the car.
Hazel in Sk is offline   Reply With Quote
Old 06-06-2015, 11:25 AM   #12
Idaho
I have a similar situation. The toyota is 17' long and the canoe is 16' long. I use a ladder rack on the passenger side, and it overhangs the side wall a little bit (easier to load). So...right turns were a concern until I tried it. I don't like the way half the canoe is unsupported in the front, so I'd recommend some sort of full over-the-cab rack where you could load the canoe from the front of the truck(with or without the trailer hooked up), and secure it well. Here's the rig:
Gordon in Idaho is offline   Reply With Quote
Old 06-06-2015, 11:57 AM   #13
Thanks so much for all the helpful info; I'm feeling much more comfortable with the whole idea. We do have a cap on the truck, so it will have more support. Not sure how to go about loading canoe over the front though.
Old 06-06-2015, 12:05 PM   #14
Nor I. I load and unload from the side. Would be easier if I had help.
From your description, it sounds like you want two racks on or over the cap.
Canoeing in Canada james kent General Chat 8 07-16-2006 01:47 AM
