Ham Radio - Page 7 - Fiberglass RV
Old 10-07-2013, 06:26 AM   #85
GMike A's Avatar
Big shopping list. This is what comes to mind at first choice but I will think about your comments.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 10-07-2013, 08:19 AM   #86
Night Sailor's Avatar
Connecticut
I have everything but the cell phone booster and some of the Wago terminals. For the Wago's wires are crimped into a square cross section with a ferrule crimper. I need to pick up more ferrules too.
http://www.wago.us/products/274.htm
Old 10-07-2013, 08:36 AM   #87
GMike A's Avatar
I bought a Wilson and really like it. I have it mounted in my car but its flexible enough to move around. I intend on having my rig in my egg but probably not to the extent that you are doing. Will be interested to see how yours comes along
Mike
K5NAN
"Miss Adventures"
Old 10-07-2013, 09:00 AM   #88
Wisconsin
While camping this last summer at a National Forest campground,,NWS issued severe weather warnings for the area.The Jeep has 2 meters and the Scamp has HH dual band with external antenna.It was great being able to contact local hams on their repeaters to know what they were seeing on radar,and advise others in the campground as to what was happening.
Al,KC9DOR
NicoletRamblerAl is offline   Reply With Quote
Old 10-07-2013, 09:46 AM   #89
Trailer: 13 foot Scamp
Originally Posted by Donna D. View Post
Byron, looks like you should add lights to the top of the mast to help those low(er) flying planes!
or drones!
Rod P is offline   Reply With Quote
Old 10-07-2013, 09:54 AM   #90
Looks Good. Not like to good old days of Ham radio when you could mess up everyone's TV within a two block radius.
I still have my old equipment including a booster. I just need an antenna and thought about firing it up for the fun of it. Maybe I will run down to RadioShack to see what they might have these days other than toys and cell phones.
Old 10-07-2013, 11:31 AM   #91
portable ham shack
I'm not planning to mount any antennas on the Scamp. At most would mount a pipe to act as a socket for a vertical. I use mostly a PAC-12 at this time but have just built a buddi-pole and buddi-stick that I need to get tuned and set.
All my operation is QRP using one of a variety of rigs. Primary is probably the KX-1 but occasionally use an IC-703 or FT-817 on SSB.
Last time out my only contacts were via PSK-31 using a PSK-20.
To be honest - the intent is as much to get together with some of the other portable, QRP ops and BS as much as play radio
Regards,
ray W0PFO
rcadmus is offline   Reply With Quote
Old 10-08-2013, 02:28 PM   #92
Ed Harris's Avatar
Right after the Joplin Tornado hit I was called up by Satern and unleashed upon them Ham in Egg!
We used my 7000 and Buddi-Pole to run the Sarern Net every day that I was there and the antenna was just mounted on a single speaker tripod with painters pole extended and we got decent signal reports like that somehow?
I have 2 main portable setups that I bring in the egg.
1 is the 7000 and an FT90 in a Pelican case with power supply ready to be opened and feed line attached in under 30 seconds.
The other is the same idea but with an 817 and LDG Tuner along with a small 2 meter amp in an even smaller case.
There is a Super Antenna in there and a Miracle whip and a Beach Bob ground plane for 2 and 440 in there too!
I have thought of mounting something in the trailer but most of my time in radio is in public service really and it is handier for me to have them all ready to go in a box at all times.
I have actually developed a simple but universal radio mounting system that allows for standardization and reconfiguration in very short times and I can move any radio in any box that I have it in in less than 5 minutes and be portable again in differnt setups.
I also always have some wire with me and have hung dipoles and windows in the parks but carefully.
I bring a tripod for my TV antenna and can mount another antenna to the mast for that one as long as I don't use them at the same time and let smoke out of the TV!
I am looking for a Hot Stick for flipping pole mounted high voltage disconnects now.
We use them for MS Ride net control and they are amazing and expensive.
If I can find one cheap enough,it will be mine!
I also love mountain top HT work in Colorado and I have hit 250 to 300 miles with an HT from several 14ers to the Denver repeaters,it is a thrill for sure.
I also listen to Shortwave in the Egg and it is great when there is less noise on the bands than in the city where I live.
Ed Harris is online now   Reply With Quote
Old 10-08-2013, 03:13 PM   #93
My portable ham shack/station...
I carry my hf radio (FT-857D) in a home made box that's patterned after a sewing machine case. The top lifts off and the radio, signal link, and seldom used tuner are there ready to use.
I carry a couple of antennas with me, 20 Meter EndFedz, 40 meter EndFedz, 10, 20, 40 meter EndFedz. The Triband is only good for 25 Watts. The two mono banders are good for 200 watts. I also carry a Buddie Pole with extended length mast.
To deploy the EndFedz antennas I have two telescoping fiberglass poles, one at 52' one one at 19'. With these I can make the EndFedz antennas slopers. To hold the fiberglass poles I pound into the ground two short steel fence posts and lash the fiberglass poles to them with bungie cords.
The radio is powered by a 50 amp hour gelcell battery which is recharged with a 65 Watt Solar panel. Set up and take down 15 to 20 minutes each.
Sometimes only one fiberglass pole is used and I operate on the tailgate of the truck. Sometimes I move the battery to a table and operate there. So far I haven't really operated from inside the trailer, but it wouldn't be difficult to do, just the antenna coax and the power wire in through the 120 power cord opening. Set the battery under the trailer.
For VHF/UHF I have a FT8800 mounted in the tow a pretty short antenna on the truck can be easily switched out for a supergainer.
Old 10-08-2013, 03:23 PM   #94
GMike A's Avatar
Thanks for sharing all the info guys. Good read!!!!
Mike
K5NAN
"Miss Adventures"
Old 10-10-2013, 09:37 PM   #95
Connecticut
Originally Posted by NicoletRamblerAl View Post
While camping this last summer at a National Forest campground,,NWS issued severe weather warnings for the area.The Jeep has 2 meters and the Scamp has HH dual band with external antenna.It was great being able to contact local hams on their repeaters to know what they were seeing on radar,and advise others in the campground as to what was happening. Al,KC9DOR
What do you use for an antenna on the Jeep. Is it a Wrangler? I have been wanting a Wrangler for years and may get one in the next few years. A friend of mine had a 2 meter Icom on his Wrangler. He used a mast on the back.
I was also wondering what you had for an dual band antenna you had on the scamp.
Old 10-10-2013, 09:38 PM   #96
Connecticut
I would avoid Radio Shack. Ham Radio Outlet can deliver anything in 24 hours.
Old 10-10-2013, 10:12 PM   #97
Connecticut
Originally Posted by rcadmus View Post
I'm not planning to mount any antennas on the Scamp. At most would mount a pipe to act as a socket for a vertical. I use mostly a PAC-12 at this time but have just built a buddi-pole and buddi-stick that I need to get tuned and set. <snip> Last time out my only contacts were via PSK-31 using a PSK-20. To be honest - the intent is as much to get together with some of the other portable, QRP ops and BS as much as play radio Regards, ray W0PFO
Not sure what a buddy pole is. Is that an external pole on stand offs? It sounds like a great idea.
I am a rag chewer too Ray.
Conrad
Old 10-10-2013, 10:41 PM   #98
Conrad
Buddi pole antenna is portable dipole antenna. I also have one that I use at times. It's proven to be pretty effective.
Check it out here.
CB radio in BC ronsmith100 General Chat 10 04-23-2009 10:42 PM
Emergency Radio Bigfoot Mike Fulltiming in a Molded Fiberglass Trailer 14 09-03-2007 06:24 PM
TV/DVD/CD/Radio/ Stereo LeBoutillier Modifications, Alterations and Updates 23 03-27-2006 09:20 PM
CB Radio... got it for free! Al Stansell General Chat 18 01-30-2006 06:36 PM
Radio Antenna Legacy Posts Modifications, Alterations and Updates 18 07-10-2003 10:03 AM
