Went to see "Ollieva" today! - Fiberglass RV
Old 01-12-2017, 07:47 PM   #1
vintageracer's Avatar
Name: To Infinity & Beyond!
Trailer: Uhaul CT 13 & 1977 Argosy 6.0 Minuet
Stopped in at Oliver Camper Trailers in "Hole in the Wall" Tennessee on my way back home to "Hillbilly Hollywood TN". Spent a nice 1 1/2 hours with the fine folks at Oliver.
I got to see the latest and greatest from Oliver on display in their showroom. Very impressive trailer. It should be at $50K+!
Jason gave me a personal tour of the production facility. The trailers are made at the Oliver Fiberglass Products manufacturing plant in Hohenwald TN. Oliver Fiberglass manufacturer's fiberglass bath tub shells for any number of manufacturers. They make LOT'S of fiberglass tubs shells to the tune of 500+ units per week! Pretty obvious where the real money is made that supports the trailer division.
I must say that the the Oliver trailer is very impressive particularly the way the unit is designed and constructed. With Oliver Fiberglass Products being the parent company it is very obvious very quickly their expertise in fiberglass shell design, fabrication and assembly. Their fiberglass work is first class. Looking at the bare shells you can see the engineering that has gone into the design and fabrication of the shells such as the different thickness "honeycomb" sheets incorporated in the fabrication of the fiberglass shell for strength and rigidity. The fit and finish is first class. The fabrication of the aluminum trailer chassis is also in-house along with almost everything else besides the obvious such as windows, axles, wheels, appliances etc. All the wiring harness's are fabricated in-house with every trailer from a cheap no option trailer to a "Hard Loaded" trailer all receiving the same wiring harness so for any future upgrades the wiring is already there. The one item that did surprise me with the wiring harness in the trailer with the small use of Romex solid core wiring in the trailer. Most all the wiring in the trailer is "Stranded wire". I asked why solid core "House Wire" was used in the trailer and Jason had no answer. Yes I know other manufacturer's use Romex in trailers however Romex does not play well with vibration issues so I was surprised to see that in these trailers. I expected they would follow the "Boating Industry" standard and use "Stranded Wire". Also included in all trailers are the attachment points for things such as awnings (both sides), solar, A/C etc. Currently the only wood structure in the trailer is slide in drawer rack below the sink/cooktop. This is also fabricated in-house. When asked WHY WOOD the response is that they are currently looking at making a molded drawer insert however that has not made it into production at this point. The inner/outer shell design is interesting and allows for some unique placement of the tanks, wiring and electrical. All is first class right down to the sliding 4 battery tray. The trailer frame uses 3,500# axles with "Buggy Springs" for the suspension. No "Torsion Axles" here! Brakes are standard along with aluminum wheels and Michelin tires. The design and cover on the propane bottle is very nice along with the optional Generator stand and hookups. Instant on Hot water heaters are an option along with a nice roof mounted solar system, Domestic A/C and a nice LARGE refrigerator.
I am told that production is currently 2 trailers a week with consideration of going to 3/week. Current lead time from purchase to delivery is 10-12 weeks. They currently have several trailers in production that could be purchased (Inventory if you will) if so desired. There were at least 15+ trailers on the production line today during my visit with the fiberglass shop in current production of more shells for current orders. Oliver also maintains a repair, warranty and upgrade center in a portion of the 500,000 square foot Oliver Fiberglass production facility. There were currently 7-8 trailers in this section of the facility from customers for upgrades.
Overall a very nice product that is more impressive AFTER you truly see whats UNDERNEATH all the glitz and glamour that is an Oliver Fiberglass trailer.
So the $50K question.
Is it worth it????
Yes!
Having seen the construction methods, materials used, parts fabrication and design used in other manufacturer's fiberglass trailers costing $20K-$35K and then comparing these competitors fiberglass trailers to the Oliver "I" can say that yes there is is $20K+ worth of additional value in the Oliver trailer. It's construction and materials aspect that you cannot readily see on the outside of an Oliver that makes these trailer's special. Although still an EXPENSIVE "Expenditure" (Not Investment) I believe it's worth that expenditure if you are looking for the a top of the line fiberglass RV that will provide many years of fun and product satisfaction.
That's something that is VERY HARD TO FIND in the RV Industry TODAY!
One man's OPINION!
vintageracer is offline   Reply With Quote
Old 01-12-2017, 09:20 PM   #2
Civilguy's Avatar
Puget Sound, WA
Mike,
That's nice to hear. One thing I expected when I started looking at trailers was to find finely-crafted dry warm spaces with lots of birch like boats used to be built...
...given what most RVs actually are, I guess we both know that I didn't find it.
I'm hoping to add a little workmanship to our Casita before the time comes when I have to give it up and pass it along to someone else. Hopefully that day is some distance off, especially since I am sooo slow.
Most of what I've done the past year-plus has been experiencing and learning about the trailer, and planning. However, I do anticipate shifting to actual-action here soon.
~ "This post is a natural product. Slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects." ~
Old 01-13-2017, 11:38 AM   #3
Trailer: Escape 2013 19 ft
Is it worth it????
Yes!
One man's OPINION!
Having seen up close a Oliver more then once ,and having some knowledge of construction . I would say this is a great assessment of a Oliver trailer . I also would say we totally agree . Pat
LindaandPat is offline   Reply With Quote
Old 01-13-2017, 06:33 PM   #4
BatDude's Avatar
Trailer: Escape
Dang you Vintage racer!
OK first what were you racing?
I did a Mini-Cooper for a season then migrated to Formula Fords.
Fie on you Vintage Racer...
OK after learning we can now tow much more with our new TV and content with our 16' Scamp I had no inclinations that anything larger that we could tow was out there in the U.S. of A.
So now you post about the Oliver factory! Eeeek.
So an Ollie Legacy Elite II may be more suited for semi-full timing especially in more cooler (read below freezing nights) northern climates.
We now need determine what our future goals are... while still physically/mentally able to travel and continue adventure for Chapter III of life.
Stick with what we have or move up to more stuff? The thought of sleeping through each night for two tall people is appealing.
Guess we will await until our winter trip is over and see if we stick with our Scamp, or put it up for grabs and go for the Ollie?
Cheers,
Bat Dude
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 01-13-2017, 08:30 PM   #5
I raced a 1966 Shelby GT350 for almost 10 years and also raced 1969 Datsun 510 for about 5 years during and after racing the Shelby GT350.
Ran HSR, SVRA, and most of all the other organizations. Hit all the famous and not so famous tracks around the country. Only made the California once.
Here are 2 pics of the cars with the Shelby at the chicane at Watkins Glen and the Datsun 510 at the SS'S at Road Atlanta.
By far the most fun I have ever had with any motorized or non-motorized vehicle!
zippousvintagegrandprix 2004  strinich GT350.jpg   1969_Datsun_510_SCCA_Race_Car_For_Sale_Front_resize.jpg
Old 01-13-2017, 09:56 PM   #6
DeanCHS1980's Avatar
Kentucky
Mike,
GREAT write up of your Oliver tour. We attended their September Rally and toured the plant. Loved it!
Take care,
Dean
Laura & Dean | '05 Casita 17' FD | '09 Kia Borrego Limited V8 2WD
DeanCHS1980 is offline   Reply With Quote
Old 01-14-2017, 10:03 PM   #7
Trailer: The BIG "O"
New Hampshire
Cheers,
Bat Dude
Bat Dude, there is currently a used Oliver for sale in Michigan....
RandyNH is offline   Reply With Quote
Old 01-14-2017, 11:46 PM   #8
Name: Reed & Karen
Trailer: Oliver
You must have seen ours in the process of being made This pic was from last week.
Reed & Karen
fr2bhpy is offline   Reply With Quote
Went to a SP and a "Scamp Camp" broke out Timber Wolf General Chat 4 01-06-2015 01:29 PM
Went to see a Parkliner Ruthies Radiola General Chat 3 06-09-2012 06:32 PM
"New" MF brand, went to see today ~ Avco Gina D. General Chat 35 01-12-2012 07:44 PM
" The night the light went out in kingston " Perry Mac Donald Problem Solving | Owners Helping Owners 1 07-26-2009 06:31 AM
Went to an RV show today General Chat 0 01-01-1970 12:00 AM
