1976 trillium - door pops open - Fiberglass RV
Old 07-14-2017, 08:30 PM   #1
Trailer: Trillium
Just wondering what would cause my door to pop open when driving it was locked when we left but seemed to have unlocked itself on a bumpy road. I font notice any door sag at all.
Thank you so much for the help.
Tracyl is offline   Reply With Quote
Old 07-15-2017, 02:54 AM   #2
Borrego Dave's Avatar
Hi, have to ask if the door was really unlocked or just opened on the bumpy road. I haven't had that problem but these TTs can flex quite a bit so a lockset that is warn may not be latching as well as it did. Can you see how far the latch is going past the catch?
Old 07-15-2017, 06:05 AM   #3
Trailer: 1980Trillium 1300
Same problem here, it happened once a while in driving, not always though. The cause is door sag combined with loose bolts of door hinges. After take a closed look from inside when door locked, I finally weld a little bracket on bottom of old door frame's bracket and tighten the hinge bolts. The problem stopped since...
Thinh is offline   Reply With Quote
Old 07-15-2017, 07:09 AM   #4
Trailer: Trillium
1976 trillium
It was locked when we left . if it is the latch set where can I get a new one?
Old 07-15-2017, 09:43 AM   #5
Trailer: Former 1978 Trillium 4500 owner (now 2010 R-pod)
We always travel with a bungee cord holding the door shut just in case it should want to pop open. The same bungee cord can then be used to hold the door open when we reach our campsite
Phil 4500 is offline   Reply With Quote
Old 07-15-2017, 10:04 AM   #6
Virginia
Yes, same problem. On a bumpy road I realized I was leaving a trail of MRE's thru the woods! The door was locked as it swung wide, lol! Now we bungee it for travel like Phil said.
sharon_b is offline   Reply With Quote
Old 07-15-2017, 12:15 PM   #7
Trailer: Trillium
Were do you bungy it to I can see to f8nd a spot. Do you happen to have a photo of how you do it?
Thanks
Old 07-15-2017, 03:18 PM   #8
Don't know what type of door latch you have, but a trick - we did on the Scamp was to reverse the outside handle. Normally both the inside and outside handles point toward the hinge side, and you push down to open the door. The weight of the handles may be enough to unlatch it when you hit a bump.
With the outside handle reversed it points the other way and counterbalances the inner handle. An added benefit is that if a stranger tries to open the door by pulling down, they will think it is locked. You will have to lift it.
Old 07-15-2017, 03:53 PM   #9
Trailer: Trillium
Our handle is different I think it is a latch style thst you pull out it lays flat to the door . hmmmm
Old 07-15-2017, 04:23 PM   #10
Then you need a different solution. WE had also added a dead bolt to our Scamp.
But did not need to engage it while traveling
Old 07-15-2017, 06:41 PM   #11
Virginia
I hook the bungee to the door's window crank & to the cooler handle or the cabinet door knob (around the corner).
Old 07-16-2017, 09:59 AM   #12
Trailer: Trillium
I think we mat add a deadbolt idea just to be safe
trillium
Porn pops?? Scouter Dave General Chat 18 04-19-2012 06:48 PM
The open door james kent Modifications, Alterations and Updates 9 03-02-2007 10:15 PM
Gremlins open the door? John & Sandy M Problem Solving | Owners Helping Owners 25 12-24-2005 05:38 PM
Keeping door open? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 06-05-2003 03:37 PM
Holding Open (UP) Upper Cabinet door Legacy Posts Problem Solving | Owners Helping Owners 15 05-18-2003 07:48 PM
