Burro 17 - Fiberglass RV
Old 05-06-2017, 09:42 PM   #1
Trailer: Borro
Burro 17
Hi , I'm new here. I'm excited to be on this forum there is a lot of knowledge and wisdom. I am in the process of fixing her up. This is going to be a challenge....this 1985 burro had carpet glued everywhere and I can't figure out the best way to remove it..Any help would be awesome!!!!
ID:	105744Click image for larger version
ID:	105745Click image for larger version
ATTACH]105743[/ATTACH]
Cookie is offline   Reply With Quote
Old 05-07-2017, 05:49 AM   #2
Wow, that is a shame! All that beautiful gelcoat ruined! Burros had the inner fiberglass so you wouldn't need carpet.
What to do from here... not sure, but I'd guess sand smooth (carefully, the fiberglass is thin) and paint.
Welcome, and best wishes!
Old 05-07-2017, 08:58 AM   #3
Trailer: Borro
I know I really would love to save that gel coat, idk what kind of adhesive they used but it's a pain. Especially the ceiling it's on there thick and my lil Random orbital sander won't cut it...
Old 05-07-2017, 07:02 PM   #4
Scoboatn's Avatar
Trailer: Burro
If you are careful, a heat fun and a sharp putty knife might work to get the bulk of it off????
Scoboatn is offline   Reply With Quote
Old 05-07-2017, 07:16 PM   #5
Metal scraper will probably dig into the gel coat. If it's not too late to save it, use a plastic scraper. I would try to find some type of solvent to cut the adhesive if a heat gun won't loosen it. Looks like one of those jobs that will take a lot of time and patience. Similar to when I had to strip layers of paint off our vintage teardrop, inside and out. Took me a few months, little section at a time. EDIT; I used a air powered die grinder with the 2" scotch discs, but they would probably damage the gel coat unless you're real careful.
Old 05-07-2017, 07:30 PM   #6
Trailer: Borro
Burro 17
I pressure washed it.. its crazy how it will make tht outside look new again! I'm just going to have to take my time sanding it..
Old 05-07-2017, 08:35 PM   #7
Trailer: Borro
Thank you for the advice! Scboatn
Old 05-07-2017, 08:39 PM   #8
Trailer: Borro
Thank you for the advice I believe I'll tackle it a little everyday, what ever kind of glue it is wont scrape . I found a solvent it that some what works it's a gel, but very very messy. I appreciate y'all sharing your wisdom!
burro
Burro Widebody, Burro and UHaul Nancy Reeves Problem Solving | Owners Helping Owners 16 05-01-2019 02:42 PM
Project Burro- 1978 Burro 13 foot Scott B. Classified Archives 0 08-09-2009 11:19 PM
I've got a Burro Manual and Burro Waxing Tips!! Amy P Problem Solving | Owners Helping Owners 9 07-28-2009 08:20 AM
Still looking: for Burro or Burro clone, wide body, 14' to 17' Penney H. & Mike E. Wanted: Molded Fiberglass Travel Trailers 0 08-29-2007 07:48 PM
