Fellow eggers, a little advice on Generators please. - Fiberglass RV
Click Here to Login
Old 01-27-2012, 12:02 AM   #1
Trailer: Casita Liberty
Howdy, I'm new to this forum, fiberglass RV's and in fact RVing in general. I just purchased my first RV, a 17' Casita Liberty Delux. Picked it up in Rice, Tx, and drove it home three weeks ago. So I guess my first trip is now complete. I learned some lessons (like not to leave the water hooked up when temps dip below 20 degrees overnight). And I now have a whole list of questions, the first one is regarding generators.
I intend on using the Casita (mostly) for boondocking, so a good generator is in order. I have done some research on various generators, and as you all know, space is a limiting factor. I'd like to be able to run the AC, and other various appliances, but I'm not sure how much generator I need. I've seen Honda and Yamaha generators in the 2000 watt range, but they seem really expensive compared to other brands in that range. What makes those ones worth nearly double their off brand counterparts? If 2k is insufficient, then would it be better to get one 3k watt generator, or two 2k watt ones in parallel?
rgbekker is offline   Reply With Quote
Old 01-27-2012, 01:39 AM   #2
Roger M's Avatar
Hi Rob, welcome to the forum and congratulations on your new Casita. They are a fantastic product.
To run the AC while boondocking a generator certainly in order. The genset of choice is the Honda EU2000i which will handle starting most 13500btu AC's. Casita installs a hard start capacitor with the AC as I recall so you should be good to go. If not or the capacitor is ineffective I believe a larger one can be installed. However, many people rarely use the AC but still boondock, and use solar to recharge the batteries from the previous night. Changing the interior lights to LED is generally the first recommendation for power conservation. I buy the China mainland ones on eBay.
The Honda is the most popular, as reliable as the Yamaha and parts are available countrywide. Some of cheaper ones are working out well but a few hundred dollars more pays for a lot of reliability and peace of mind when you're miles from a service center.
There is a vast wealth of information and many experienced hands here on the forum who will be quite willing to answer any questions you my have.
Roger M is offline   Reply With Quote
Old 01-27-2012, 06:16 AM   #3
Trailer: 19' Scamp
Nebraska
No experience but have looked at them too.. General comment is the Honda is quieter than many of the less expensive ones too.
Earl E. November is offline   Reply With Quote
Old 01-27-2012, 06:25 AM   #4
cpaharley2008's Avatar
The Hondas and Yamaha's are twice as expensive because they are twice as quiet. The 2000 watt should be adequate, but do you really need one? They are heavy- 50lbs and require gas. I bought one and have yet had the need to use it, it stays home for emergencies.
There are several threads here on solar and LED conversions where you can boon dock without power for days. Other than your a/c and your microwave, everything else can operate off your battery( or batteries, now may be a good time to install dual) and a 40-60 watt solar panel on your roof will keep the batteries charged.
You will find your water use could be your restricting factor in boon docking!
Old 01-27-2012, 07:27 AM   #5
Trailer: scamp 13
yup, i would test things out first. you can get a tickle charger solar panel real cheap. if your like us, we are gone doing stuff most of the day.so the solar can be charging the batteries all day with no drain. find out how long your charge lasts for you. you might be way ahead money wise to add another battery and a solar panel
Old 01-27-2012, 07:50 AM   #6
Thomas G.'s Avatar
Just as a side note, a generator will not make you the most popular guy in the campground. Even the Honda and Yamaha generators have a good growl when under load. Like others, I'd encourage you to see if you really need AC, if not the price of a generator buys a lot of solar panels.
Old 01-27-2012, 10:32 AM   #7
Thanks for the advice on the trickle charger for the battery, and I am already looking into the led bulb replacements. I hear what you're saying about not needing the generator, and I don't figure I'll need the generator too often, but we do spend a lot of time in hot climates. Is there really that big of a difference in sound between various generators of the same wattage? When I read most of the specs of the off brands, they list about the same decibel levels as the Honda and Yamaha. Of course the method of measuring those sound levels can be vastly different, and the noisier ones can be fudging the numbers so they "look" similar to the better brands. I'd love to be able to see them all (and hear them all), in one location, but I can't find anyplace that caries more than one or two brands at a time, and NO place I’ve found lets you run them.
Old 01-27-2012, 10:34 AM   #8
If you go to a Yamaha dealer or a Honda dealer they will run the unit before you buy, the other brands are unknown.
Old 01-27-2012, 10:40 AM   #9
You will find your water use could be your restricting factor in boon docking![/QUOTE]
I hear ya on that one, but my wife and I are used to camping, and using very little water. I didn't get the extended water tank, but I can carry lots of water in my TV, plus I can make water from virtually any source.
Old 01-27-2012, 10:51 AM   #10
I figure most of the RV campgrounds these days have electrical hookups, and if not then I'd more likely be boondocking on my own. I'm not a big fan of campgrounds anyway. If anyone can hear the generator then I’m WAY too close to them, and likely should move on.
I've considered solar, but in order to run the 110V stuff, I'd need a good bank of panels, plus several deep cycle batteries, which will all add bulk and weight, and would cost even more. I suppose I should develop several “kits” depending on the type of camping we plan to do. One of those being with a generator, one solar, and one for electrical hookups. Thanks for helping move my thought process along!
Old 01-27-2012, 11:24 AM   #11
Roger M's Avatar
I would venture to say the advertised db levels of the major brands at least are a reliable indicator of relative loudness. As an acoustical measurement of sound pressure levels, and the decibel is not a linear but exponential unit. They are measured at specific distances i.e. 3 meters, but finding that info can be difficult. With a db meter app on your smartphone you could measure it yourself.
Try a YouTube search for videos of generator comparisons, otherwise don't get hung up on a db or two. Once running the genny for AC in hot weather most people are doing the same. The hours of operation are usually the issue in campgrounds. Boondocking, the gen can be placed 25-50 away using suitable cable and a baffle can be placed to reflect sound away from the trailer which will have a noticeable effect.
In other words, the Honda, Yamaha and perhaps the Robin/Briggs and Stratton are the recommended brands for running AC, all still manufactured in Japan (wisesales.com).
Old 01-27-2012, 12:42 PM   #12
WildBirder's Avatar
I would focus on Rogers point above that it is exponential. A difference of .1 db is not .1 greater (10% of 1.0) but a multiple number of times greater. And the higher you get the bigger the jump between numbers. I may be pointing out the obvious or being redundant to some readers but I felt it was important for those that may have skimmed over it.
Cheers,
Mark
WildBirder is offline   Reply With Quote
Old 01-27-2012, 12:46 PM   #13
Bruce H's Avatar
Trailer: Bigfoot 21 ft Front Bedroom
Hi Rob,
You are correct. unless you spend all your time camping in the mountains there will be times when air conditioning is an absolute necessity if you want to sleep. There is no battery or solar system that will run an air conditioner for very long. I had owned a trailer for about three years before I got a generator and I wish I had done it at the beginning. I once got caught at a rest area along I-5 in the Central Valley when it was 107 degrees. I had only slept about two hours the night before and I ran out of steam. I had the air conditioner but no generator. That was a hot one hour nap. You don't have to run a generator every day but having it available is valuable.
I bought a Yamaha ef2400is (2400 watt) generator from Wise Equipment about four years ago. At the time they had the best price on the internet. It was still over $1,100. It was the smallest one I could find that was advertised to have the capacity to start a 13.5 rv air conditioner. It was also the lightest and quietest one that would do that. I love it. It weighs around 70 lbs. That is still enough to throw your back out but it is way better than one that weighs 150 lbs. You will have to be lifting and moving your generator around.
$1,100 is not cheap but not having to fear extreme weather and run down batterys is makes the whole experience much more enjoyable. I figure that I got a lot more value dollar for dollar on that generator than I have on a lot of other things I have spent money on.
A couple of notes: when you get a generator get some kind of cable lock to secure it when it is being used. That prevents someone from just being able to grab it and throw it in a vehicle and take off with it. Nine out of ten of them are not going to have tools to cut a cable. Also when you are not at the camp secure the generator out of sight in your trailer or vehicle.
Cheers,
Bruce
Old 01-27-2012, 01:12 PM   #14
Thanks for the tips. I just downloaded "smart tools" for my android that includes a dB meter, bubble level, height and distance meter, compass, and several other innovative tools that will come in handy on my RV adventures! Once I get a generator, I'm going to have to build myself a collapsible baffle like you described. I love modding things, and have already done several mods to the trailer, and have several more planned. I guess that's a good topic for another thread though.
Old 01-27-2012, 02:25 PM   #15
Trailer: 1996 16' Casita SD
Louisiana
Being in Louisiana and loving to camp anytime of the year, a genny is a "have to".
There's a big difference in db levels. I like the Honda 2000 the best. My AC is only 5,000 btu so it's more than enough.
Welcome to the site, I'm new to FG campers, too!
It's a great place for information and sharing your love of FG. Lots of good folks in here!
itlives is offline   Reply With Quote
Old 01-27-2012, 10:12 PM   #16
Camilla's Avatar
Trailer: Play Pac
I have a Honda 2000i I've been around some of those loud ones and it's a huge difference. Whatever you get make sure that it can handle your AC. I think it takes about twice the power to start the AC or something? In any event my Honda can't handle the AC load.
Camilla is offline   Reply With Quote
Old 01-27-2012, 11:48 PM   #17
Luckily, my Honda Genny is a 5,000 Watt (peak) unit (4500 running constant watts) with outputs for 30 amp at 120V (plus other 120V outlets that can be used at the same time) or 20 amps of 220V. Since my Bigfoot likes to have 30 Amp available at campgrounds, this is the perfect size, as it can handle everything at once (as well as being a standby power unit for the house if/when needed)
Old 01-28-2012, 10:26 AM   #18
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
How would you feel about camping and sleeping next to a running lawnmower? That's what a cheap generator sounds like.
If you're camping far from other people, you mainly have to please only yourselves and you can run what you like. If the lawnmower-volume engine noise doesn't bug you, I guess you could buy a cheapo model; while inside the trailer you might not hear the genny much over the roar of the AC anyway. Just don't fire it up in a CG or you'll get a lot of dirty looks (and maybe worse).
The Honda 2000 and Yamaha 2400 still sound like an engine, but the volume is more like people talking. Most CGs still restrict the hours that one can use a genny to certain daytime periods, though, so if you're in someplace without electric hookup and it's hot, you might still be sleeping without AC.
I have a 5000 btu AC. My strategy so far has been to avoid heat where possible, and where I can't avoid the heat I get a CG with electric to run the AC. I am not fond of small gas engines. The ethanol in common unleaded gas can mess up a carburetor pretty quickly if one is not religious about draining the tank and all that during periods of non-use.
Kipor makes a quiet genny that's cheaper than the Honda, but I would not recommend it. If it needs service it's hard to get parts for them, I've read.
Old 01-28-2012, 11:26 AM   #19
Denece's Avatar
Trailer: Compact II
We ran a Honda eU1000i on our sailboat. With that we could run a 5000BTU ac. The controlling factor was that it would run out of gas in about 6 hours! That was OK since it was usually cool by then but you'd wake up soaked in sweat because all the hatches were closed! We found a simple well-placed fan did a better job in assuring a good nights' sleep. Of course, we don't have asthma.
Make sure your fuel will last all night because you'll have to run it all night, or until your neighbors shut it down for ya. ;-)
Alternatively, there are very expensive 12V units for boats that will run on a good sized battery bank.
Denece is offline   Reply With Quote
Old 01-28-2012, 12:37 PM   #20
Mike Magee's Avatar
Solar could be an alternative to a generator, if it's done right. The Casita doesn't have much roof real estate, though, so I think you'd have to use freestanding panels set on the ground (but that lets you adjust the angle and direction, even location to avoid shade). Handy Bob has a blog where he talks about his solar setup with 345 watts of panels. The RV Battery Charging Puzzle « HandyBob's Blog
An excerpt from his blog page:
"We run our TV, computer, battery chargers for phone, camera, tools, etc., plus coffee maker, microwave, mattress heating pad, toaster, waffle iron, hair dryer, vacuum, power tools such as skill saw, table and miter saws, router, sander, drills, heat shrink gun, soldering iron, etc. You name it. We live a normal life, except that our house is very small. My wife watches TV while she quilts with a sewing machine, using an electric iron to press the seams and I do remodeling & repairs, including building a big deck in 2006, using power tools connected to our rig, at a remote cabin with no electric service (where it rained for three days during construction)."
With the right system, an AC unit might be operated off solar power, either thru an inverter or by use of a 12v boat AC. Handy Bob's system does use 4 6v golf cart batteries, though.
Just wanted to present one more option for you to consider.
Hi Fellow campers! Pollyg Hi, I am.... 1 11-07-2011 05:36 AM
Glass Eggers Nor West - May 28-30, 2010 Doug Mager Rallies, Get-togethers, Molded Meets (Archive) 37 07-21-2010 01:46 PM
The B.C. mainland Eggers Doug Mager Rallies, Get-togethers, Molded Meets (Archive) 0 10-05-2007 06:18 PM
anyone ever meet up with fellow site members? Doug Mager General Chat 3 05-29-2007 10:13 PM
Welcome fellow Canadians! General Chat 0 01-01-1970 12:00 AM
