Fiberglass Trailing - Fiberglass RV
Old 08-26-2017, 04:52 PM   #1
Trailer: In the market
KY
Red face Fiberglass Trailing
Hello: My wife and I have been wanting to obtain a fiberglass trailer that we can pull behind our Honda Odyssey (2094). While she would settle for a 13 footer, I want a larger trailer, because I travel doing consulting and industrial training work. We are very healthy Bluegrass Baby Bloomers.
Liteone is offline   Reply With Quote
Old 08-26-2017, 05:04 PM   #2
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Welcome! You should probably check your Honda manual for towing weight capacity and allowable tongue weight. Then, you can start your search for a FG trailer that fits those specs. I believe several members here have used a similar SUV for towing 13' and, possibly, 16' trailers. Stay tuned for their responses!
Old 08-26-2017, 06:47 PM   #3
KY
Trailers
We have checked out, and already have it hook up with trailer towing packages. I haul a work trailer with it occasionally.
Old 08-26-2017, 07:09 PM   #4
Trailer: 2013 Escape 19
More tow vehicle or go with a smaller or mid-sized trailer. Be sure to check weights in the real world. Your rig is rated to max of 3500 pounds and 350 tongue weight. That eliminates the bigger stuff. And you really don't want to be maxed out on your rating versus your trailer IMHO. Scamp 16 should fit within your limits and is a fine trailer.
The bigger ones like our Escape 19 are really roomy, but would overwhelm that Odyssey.
Scamp Axle - Leading vs Trailing RogerDat Towing, Hitching, Axles and Running Gear 70 07-01-2014 12:18 PM
Replacing an Axle - leading arm to trailing arm Roy in TO Modifications, Alterations and Updates 38 11-21-2010 02:00 AM
New Axle -- Leading or Trailing Arm? CliveAlive Towing, Hitching, Axles and Running Gear 3 01-26-2008 01:12 AM
The End of Trailer Trailing? Patrick M. General Chat 40 12-19-2007 11:13 AM
New Axle -- Leading or Trailing Arm? CliveAlive General Chat 0 12-31-1969 07:00 PM
» Virginia Campgrounds
