Thanks everyone...I checked out all the systems today and was surprised that they all seem to work...I purchased it from an older lady that had owned it for 16 years and been camping in it twice...she was selling her home and getting rid of stuff she no longer wanted to move...she told me the
fridge had never worked...I fired it up on the
propane side and it got cold very fast...so I tried the 120v side and it also worked well...it has a very dead deep-cycle as she was not even aware it had a
battery...so I did not try the 12v option...but running a
fridge off 12v seems a little strange to me anyway...the water lines were disconnected running from fresh water tank to the toilet...I hooked them back up and the pump and toilet worked like new...the city water inlet on the rear drivers side is busted and it spays water everywhere when you connect it...so I have to source something that would work there...the plastic fresh water inlet door and assembly is broken so I also need to find something that would work there as well...the stove worked like new as well...
So am I correct in assuming nothing is available for these campers anymore and I will have to source other stuff and fab it to work? I realize a lot of the stuff is pretty standard in the camper world.
It has a pretty nice pop-up section except the plastic/Velcro clear flaps are dis-formed and no longer fit/work...so I guess I will remove it and have my local upholstery guy work on it..
Also in all my teardrop builds I install a
Battery Tender and use it to keep deep-cell charged and maintained...it seems like that would work with this camper as well...I'll run another 120v outlet and install it under the bench near the
battery box to power the charger...I may upgrade the breaker box to the same one I use in all my small camper builds as well...
I will also install these outlets as they really come in handy
and probably a shore power outlet because pulling the power cord through the hole under the sink will probably get old...
Here are some bad cellphone picks of it before I start work on it
I need to source some new
tires and a wheel for a spare it seems most
tires the stock size are bias ply...anyone know where to get radial 165/80 13 trailer
tires? and a steel wheel?
Has anyone found a decent fresh water inlet?
Thanks for any info and I already love this little camper
