Going to look at a '76 Trillium: advice? - Fiberglass RV
Old 04-29-2014, 12:20 PM   #1
Trailer: In the market
Hi, all. I'm hoping to go see a 1976 Trillium 1300 that is for sale about an hour from me. The owner is asking $3300 obo and claims that all systems are working. I have not seen photos yet and will require those before I drive out there. I just wanted to see if there is anything beyond the basics of trailer-shopping that I should look out for. (Anything specific to Trilliums?) I am planning to write down the serial number if I can. (Inside the closet door, right?)
I haven't seen a Trillium in the flesh before so I'm psyched to go see it.
kapers88 is offline   Reply With Quote
Old 04-29-2014, 01:56 PM   #2
David Tilston's Avatar
Right.
Typical issues:
Missing front window rock guard, (hard to find)
Separating ensolite insulation, (fixable)
Sagging door, (easy to fix)
Leaking belly band, (less easy to fix)
Leaking windows, or more the sealant around the windows, (also less easy)
The last three are going to be common to all Trilliums that have not had a refurb.
Actually, they are fairly durable. Unless the roof is collapsed, like mine, or the floor is spongy, then they are fairly easy to fix.
Old 04-29-2014, 02:39 PM   #3
Trailer: 1978 Trillium 4500
investigate the frame issue ...
Full disclosure: I own a 4500 and have had no problems.
Read up on this:
trillium 1300 frame crack recall info
and check the frame on your specific unit.
If you find/suspect trouble ... bid lower. This is a fixable issue.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 04-29-2014, 03:54 PM   #4
Thanks. I knew you guys would have good info for me! My understanding is that I should look for a crack in the metal frame towards the front of the trailer. I'm guessing this is underneath? (Please pardon my ignorance. )
Old 04-29-2014, 04:08 PM   #5
After 38yrs. the axel is most likely shot, unless it's been replaced. Look for tire rub marks in the wheel wells.
Scott H is offline   Reply With Quote
Old 04-30-2014, 01:18 PM   #6
I see the one I am looking at made it to the listings here!
1976 Trillium camper | Canyon Lake, TX | Fiberglass RV's For Sale
So far the seller hasn't returned my call/text/email.
Old 04-30-2014, 01:30 PM   #7
The holding tank makes me wonder what kind of Trillium it is. The 1300 and 4500 never came with any holding tank, unless he just means the water tank.
Old 04-30-2014, 02:16 PM   #8
Trailer: 77 Scamp 13
Maybe they added something. The did make special mention of it.
Hmmm using my far far away vision I see a blue tank. A blue tank bungee corded someplace under a camper. It has wheels
With any of these older ones it's always a toss of the dice as to what has changed and how. And how well implemented. Could be someone installed an actual holding tank for the sink complete with stinky slinky hook up.
trillium
What to look for when buying a Trillium 4500 Bill C. Problem Solving | Owners Helping Owners 7 10-03-2016 07:13 AM
Going Going Gone ! ted saxton General Chat 2 11-16-2007 05:58 AM
Look For the small Trillium Trailer General Chat 0 01-01-1970 12:00 AM
