Originally Posted by Yamaha_gurl
Question #1: I'd like to run the fridge off of the vehicle battery while driving (6 hour trip tops), how do I make sure that it doesn't drain my vehicle battery?
Always start with a COLD fridge. Our routine is to start the 3-way fridge on 110v house power at least 36 hours before we leave. Get the temperature right on. Take your refrigerated stuff out of the house refer and put them in the correct temperature trailer refer the night before. Check on it a few hours later to make sure the temperature is OK (use a grocery store bought refer temp gauge.)
That way you can make a day run without draining the vehicle battery. You wil NEVER be able to cool the fridge on battery, At best, it can sorta hold temperature once it has been pre-cooled.
#2: Is it true that a portable generator can charge the trailer battery? (we are using the trailer for riding our sportbikes on the race track, so generators are loud and buzzing all day) We want to be able to have battery power for at least 3 days.
Generators can work, but many places limit their use.
Solar power panels may be an option.
#3. There currently is NO battery on the travel trailer, just the hook up...where on earth do I even start with what to purchase? I know deep cycle, but there seem to be SO many.
Since you don't have a battery right now, what do you have? You sould have a converter at least which allows the use of 110v house current to power the trailewr stuff. If you don't, get one with smart charging that does not overcharge your battery.
First decision is where will you mount the battery. If on the trailer toungue, then get the biggest battery box you can, and the biggest battery that fits that box. Run at least 6 gauge cable from the converter to the battery and back to a terminal block setup to distribute battery power in the trailer. Use a set of lengthy jumper cables, that's what i have. If inside (which is O.K.), I would make sure to use a sealed box that is vented to the outside.
There are many posts and discussions on this website on such topics.
Vic
