Gutted trillium outback - Fiberglass RV
Old 07-16-2016, 02:42 AM   #1
Trailer: Trillium outback
Hi I am Jeremy. Newby here. Just purchased a 2004 trillium outback. Decided to strip it down right to the fiberglass because of leaks and mold was wondering what people's thoughts are on being non insulated in a fiberglass trailer? Trying to decide if I should just give the inside a light sand and then paint it or if I should throw some foam on it.
I live in Alberta and don't plan to winter camp and I'm used to tenting, but I wonder if it may be foolish to just paint and not insulate. Thoughts?
If anyone has affordable/easy insulate ideas I would really appreciate it. Thanks!
Jeremyb is offline   Reply With Quote
Old 07-16-2016, 03:23 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Welcome to FGRV Jeremy. Hope you haven't stripped it down yet, not good. Others will chime in on that. These rigs don't do well without interior insulation....such as it is because of condensation. Some have gone that way but....
Suggest you wait till you get other info from members before putting the hands in gear. Don't ask how I learned that .
Old 07-16-2016, 03:37 AM   #3
How about spray foam?
Old 07-16-2016, 04:27 AM   #4
From some that have tried it they say it didn't work well.
Old 07-16-2016, 04:43 AM   #5
Raz
Raz's Avatar
Vermont
The reason tents are not water proof is to allow the condensation to pass through. If you use a tarp as a tent you get rained on in the morning . You need some insulation on the walls to stop the condensation. And insulating and replacing the wall covering is difficult because of the curves. Raz
Raz is online now   Reply With Quote
Old 07-16-2016, 09:08 AM   #6
What kind of lining does it currently have? The two most common, closed-cell foam and marine headliner, clean up surprisingly well with a bit of elbow grease.
Old 07-16-2016, 09:20 AM   #7
BatDude's Avatar
Trailer: Escape
FYI the spray foam may really be prone to off-gassing volatile stuff you do not want to breathe.
The rat fur, closed cell foam etc. others have suggested are fine.
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 07-16-2016, 07:50 PM   #8
If it is just a surface mold on the interior, it can be killed and cleaned to a certain point and then that can be painted over (assuming you don't have "rat fur" already. Even if you don't have plans to winter camp, even cool spring or fall mornings can be cold enough that moisture inside will condense on the cold interior surface. It then runs down and will soak cushions and bedding. If the current insulation is still there, I recommend keeping it if possible after a good cleaning. Pics posted would help with a little more specific recommendations.
I have seen people do spray foam with some success, but they took it somewhere professional so that the thickness and final skin that is on the inside of the trailer is something desirable and not super bumpy. I would think too, that there must be a spray foam rated not to off gas.
TimR is offline   Reply With Quote
Old 07-16-2016, 08:12 PM   #9
Thanks for all the replies guys, I got rid of everything...I know super bad idea but I just needed to make sure all the mold was gone completely. The insulation was just a soft white foam sorta like a thin camping mat, the fur was grayish carpet stuff.
Where can I get the closed she'll foam? Homedepot? How about rat fur?
I know I'm entering some hard times ahead, but I have a lot of time on my hands.
Old 07-16-2016, 09:44 PM   #10
I guess the peace of mind factor is important too. Not sure on the foam. Might be more of a camping store kind of thing. Others have used the reflective buble insulation. As for rat fur, many have used hull liner successfully.
Old 07-16-2016, 10:46 PM   #11
Reflectix foil bubble insulation is available from big box home stores. Rat fur is a long napped marine headliner available from Scamp. There are other, more carpet-like marine headliner products available from online suppliers. Together they make a decent lining at reasonable cost. They're easier to work with than foam.
You can also find closed cell foam online. It's more expensive and harder to fit to the curved corners than Reflectix, but it provides a little better insulation.
Old 07-18-2016, 06:22 AM   #12
Jennifer Minogue's Avatar
Trailer: Predom Prespol from Poland
We stripped the interior of our Captain trailer down to the fiberglass. Then put in 3/8" ensolite closed cell foam (from a foam dealer in Kitchener - you can probably get it in a marine store too). On top of that we put boat hull liner which lets water run right through. Looks like corduroy (sort of). You can put velcro on it. We got the boat hull liner at a local fabric store that carries everything from soup to nuts. We didn't even know it was boat hull liner at the time - it just looked like the right thing to use. You could also use car headliner (more color choice) but I'm not sure how thick it is and it might be more "wrinkly".
the Captain is more "square" without the curved upper corners. However, you can cut a pattern. If you managed to save the old liner, you could cut it from that. We used paper patterns. Measure twice, cut once.
We also used the glue recommended by the foam dealer so we didn't melt the foam into a blob with the wrong solvent. They also recommended using a sprayer for the glue and be prepared to throw it out at the end as they are a pain to clean (so buy a cheap spray).
The foam application doesn't have to be perfect as you are covering it with the liner. I think the whole job once the old liner was stripped out took about a day. with the curves, it will probably take you a bit longer.
Jennifer
Jennifer Minogue is offline   Reply With Quote
Old 07-18-2016, 10:13 AM   #13
Virginia
Jeremy, before you reinstall the insulation & wall covering, you might want to find out WHY there was mold inside - where was water getting in to cause mold? the good thing about stripping it to bare walls is you should be able to find the leak pretty easy now. I'd hate for you to go to the trouble & expense of new wall coverings & still have the same underlying problem!
sharon_b is offline   Reply With Quote
Old 07-19-2016, 01:13 PM   #14
Maryland
I have a 1977 scamp 13 that never had any insulation installed
I use it for beach camping my interior ceiling is painted like clouds and I have had no problem with condensation, again I only use it in the summer months. and honestly if I get a little I'm no t to worried about it. I was installing my new fantastic fan when I took this pic
tigger is offline   Reply With Quote
trillium
Fiber Stream Camper (gutted) Joanne P Classified Archives 1 08-01-2009 07:52 PM
Gutted Unit West Coast BC Glen Wanted: Molded Fiberglass Travel Trailers 0 05-04-2009 06:08 PM
SOLD: Completely gutted 1990 16' Scamp - $1200 Kristi Warner Classified Archives 11 08-22-2008 06:36 PM
He gutted the trailer! Gwenn Problem Solving | Owners Helping Owners 6 08-24-2007 05:47 AM
Gutted 13'-16' Wanted Glen Aldridge Wanted: Molded Fiberglass Travel Trailers 3 01-05-2007 09:33 PM
