Hello all - Fiberglass RV
Old 11-27-2015, 09:39 PM   #1
Trailer: currently shopping
Hello all
New guy here, no camper but looking for something like a Casita or Scamp. I live in Blairsville Ga. Do not want anything bigger then a 16 footer. Looking forward to learning more as I read the forums.
Mike Sharkey
Mike Sharkey is offline   Reply With Quote
Old 11-27-2015, 10:10 PM   #2
Welcome, Mike!
A good place to start your research is the thread "Trailer Weights in the Real World" in the General Chat section. Don't know what you're planning to tow with, but this thread, along with the towing section of your vehicle's owner's manual, will get you started in the right direction. Post #297 links to a downloadable spreadsheet of the data you can filter by make and model and calculate averages.
Best wishes in your "egg hunt"!
Old 11-27-2015, 10:17 PM   #3
Thank You Jon, I have a 2010 Toyota Tacoma Prerunner. It has the towing package and V6. I dhould also add that I'm looking for and older trailer that has air but not the unit on the roof.
Mike
Old 11-27-2015, 10:22 PM   #4
Hello all
Sounds like you're in good shape then! Just gotta find one... often takes some persistence.
Another helpful resource is the "Buyer's Checklist." On the website, go to the tab at the top that says "More" and select the "Document Center." If you look down a few rows you should find a link.
Old 11-28-2015, 08:18 AM   #5
Direct Link: Fiberglass RV - Document Center - Buyers Check List
Old 11-28-2015, 08:40 AM   #6
Mike
Hi Mike and welcome to the group.
Just to ask... Are you planning on putting it inside?
and... "Older" often doesn't mean less expensive but, if so, it can alsomean a lot more work is needed.
Best bet, especially for a first unit, set a budget and buy the very best you can afford, it's usually cheaper than buying a fixer, that is unless you are looking for a hobby and/or a form of self inflicted pain... LOL
Old 11-28-2015, 08:53 AM   #7
Bob I have a drive thru garage with an 8 foot door on each side. I live in the mountains of north Georgia. I would prefer the air conditioner not be on the roof so I could drive it through the garage.
Old 11-28-2015, 09:15 AM   #8
Hello all
Check the actual measurements of your door opening, Mike. It could be a bit less than a full 8'.
Official manufacturer's height of a 16' Casita is 7'8", and Casita mounts factory AC through a front closet on the 16'er. Official height of a 16' Scamp without roof AC is 7'10". Early units had factory AC installed in a side closet; sometime(?) they switched to a roof mount. As far as I know, both specifications have remained unchanged over the years, subject to minor variations.
Since both are close to 8', and since modifications (new axle, larger tires,...) can affect the height, you'll want to check each unit you find on a case-by-case basis.
Hello All, More Noobs DeadEyeDan Hi, I am.... 4 07-18-2011 07:21 PM
Hello Thanks to All LLN General Chat 9 10-07-2010 04:29 PM
hello all....couple of questions about a big mod thenoob Problem Solving | Owners Helping Owners 14 09-17-2010 10:01 PM
Hello All Buck62 General Chat 8 12-06-2006 03:43 PM
All Okra, all the time CharlynnT General Chat 0 05-04-2006 02:05 AM
