Hello from Ohio + Question - Fiberglass RV
Old 01-12-2019, 10:26 AM   #1
Trailer: In the market
Ohio
First post here. Looking for a used egg. Have owned a few older trailers (75 Scotty, 75 Avion).
I am thinking about going to look at a 1987 16’ scamp that’s about 5 hours away. My main concern at this point is how wavy the sides of the camper look. It may be perfectly normal...I don’t know. Here is a link to the craigslist add:
https://evansville.craigslist.org/rv...769149570.html
Photo 1 and 3 are what I am worried about.
Thanks everyone.
W123suv is offline   Reply With Quote
Old 01-12-2019, 11:51 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Welcome to FGRV Matthew. I can't give any info on the waves but the door shape and seal look to be great. The curved doors often seem to loose their shape at the bottom and leave a gap for water, bugs and such to enter. There's a "buyers check list" you can pull up and use to help you know what to look for with these eggs. Good luck on your search.
Borrego Dave is online now   Reply With Quote
Old 01-13-2019, 06:38 AM   #3
Slight waviness is normal. The fiberglass is pretty thin. Normally it is not too noticeable, but if the light comes from an oblique angle it can be accentuated. If all the interior cabinets and supports are in place, and if all the rivets are tight (give the acorn nuts on the inside a twist with your fingers), then I wouldn’t worry.
Do check the frame underneath carefully, especially under the front of the cabin where the A-frame bends. Scamp used a lighter frame on these older units and occasional failures do occur, most commonly on the street side bend.
Old 01-13-2019, 09:17 AM   #4
JBB
JBB's Avatar
Trailer: 2017 Lil Snoozy
South Carolina
Welcome Matthew! It seems that the seller of your link has deleted the post. Good luck in your search!
JBB is offline   Reply With Quote
Old 01-13-2019, 09:23 AM   #5
Ohio
Thank you all for the advice. I will take a detailed look at the frame. I believe he just reposted:
https://evansville.craigslist.org/rv...793785881.html
Old 01-14-2019, 07:26 AM   #6
Trailer: Scamp 13 & TDI tugboat
Ohio
That looks like a well optioned trailer. Fridge, hot & cold water, full bath, furnace, AC, microwave...
Needs cleaned, new tires, service brakes & bearings... And then hit the road!
If you're in central Ohio, and would like an experienced eye to check it out after you get it home, ping me. Or if you want to see a similar vintage Scamp.
Good luck!
Cheers,
Jim C & a 1983 Scamp 13
FJ40Jim is offline   Reply With Quote
Hello from NW Ohio scotthall8x10 Hi, I am.... 7 03-18-2018 08:09 PM
hello hello robert from california hangemhigh Hi, I am.... 15 03-11-2017 07:08 PM
Hello from Ohio! michele4bob Hi, I am.... 17 01-25-2015 01:21 AM
2nd Annual OHIO Fall Gathering (REVISED) Sandy W Rallies, Get-togethers, Molded Meets (Archive) 1 09-21-2006 07:26 PM
2nd Annual OHIO Fall Gathering Sandy W Rallies, Get-togethers, Molded Meets (Archive) 2 06-05-2006 05:26 PM
