Hello from Tallahassee - Page 2 - Fiberglass RV
Old 03-08-2018, 05:43 AM   #15
DeanCHS1980's Avatar
Kentucky
Hi Pete,
Welcome! Look forward to meeting you at GE&H VIII next week. We are in our 3rd season with our ‘05 Casita 17’ FD. LOVE IT!
Take care,
Dean
Laura & Dean | '05 Casita 17' FD | '09 Kia Borrego Limited V8 2WD
DeanCHS1980 is offline   Reply With Quote
Old 03-08-2018, 07:31 AM   #16
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Hey Pete,
As dblcola posted, we have a 2003 Casita 17SD .
We do tow it with an 09 Ridgeline. It was born with AWD as were all Ridgelines those years. It does a great job of towing the Casita and near perfect as our "GO TO" vehicle for trips.
Our Casita is slightly modified to meet our needs. We bought it as the 3rd owners January 2011. It needed a lot of TLC.
I don't have the skills or patience or imagination to transform it to look like some of the beauties you will see at GE&H. But it suits us to a "T".
Come on by and visit us, site 015.
Should mention that dblcola has had just about every configuration of camper, there is. It looks like he is settling down with the Casita he purchased in the last few months.
kip
Kip in Ga. is offline   Reply With Quote
Old 03-08-2018, 09:26 AM   #17
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I have a 2013 Ridgeline that has towed first my Bigfoot and now my Escape, for 10,000 miles/year, Include a cross-continent round trip last Fall. Both trailers are heavier than a 17' Casita and the Ridgeline towed them with ease, including all over the Canadian Rockies. And BTW I use an anti sway bar but no WDH.
You'll have no problems.
Walt
Old 03-08-2018, 03:02 PM   #18
Trailer: Currently Shopping
FL
Originally Posted by Kip in Ga. View Post
Hey Pete,
kip
Kip, I've got the RTL-E with AWD. Robert in Tallahasse has a 2017 Ridgeline AWD and he says it tows his Casita 17 Independence with no problem. I will look you up at the Gathering.
Pete_Tallahassee is offline   Reply With Quote
Old 03-08-2018, 03:32 PM   #19
FL
Thanks
Walt
Walt, I'm confident my Ridgeline will tow a Casita. It's AWD and rated for 5,000 lbs. Hope to see you on the road one day.
Old 03-08-2018, 03:51 PM   #20
The issue with the Casita 17D is tongue weight, which can easily exceed 400 pounds. That limits how much cargo you can carry in the back of the Ridgeline without overloading the independent rear axle. Obviously others have made it work, but it is something to take into consideration as you plan.
If the Ridgeline is anything like my Pilot, Honda is very clear and detailed in the owner's manual about how passengers and cargo affect the tow ratings.
Old 03-08-2018, 04:01 PM   #21
WaltP's Avatar
SW Virginia
The issue with the Casita 17D is tongue weight, which can easily exceed 400 pounds. That limits how much cargo you can carry in the back of the vehicle without overloading the independent rear axle. Obviously others have made it work, but it is something to take into consideration as you plan.
Yup, the Ridgeline is actually a SUV (Pilot) disguised to look like a pickup.
If I recall correctly the tongue weight rating of my Ridgeline is 600 lb. The tongue weight on my Escape fully loaded, including full fresh water tank, measured at 410 lb.
Walt
Old 03-08-2018, 04:15 PM   #22
Walt
My 17B tongue weight is 320 - 340 lbs loaded. Fresh water tank is aft of the axle so when full would unweight the tongue. Not sure how you manage to get to 410 lbs. Is there that much difference between 2008 and 2017?
Old 03-08-2018, 06:04 PM   #23
FL
Tongue Weight
Never really thought about Tongue Weight. I'll look into it.
I will be carrying a 350 lb Honda CRF 250 L motorcycle in the truck bed.
Anyone hear of someone putting that much weight on the front or back of the Casita? It would free up the truck bed so I could put a cap or tonneau cover over the bed. Just a thought.
Old 03-08-2018, 06:37 PM   #24
WaltP's Avatar
SW Virginia
Not sure. They are a new design, with new molds and all. And I have the front bin on the tongue well loaded.
Walt
Old 03-08-2018, 07:37 PM   #25
Walt
That would do it. I don't have that bin.
Old 03-08-2018, 08:57 PM   #26
The cap or tonneau adds its own weight, especially a cap.
As to the bike, the truck bed is definitely the best place. Hanging it from the back of the trailer will reduce tongue weight and can cause the trailer to become unstable (sway). More important, I doubt the frame is designed to carry that much weight back there. It's not just the static load, but what happens when you hit a bump and the back of the trailer does a whoop-de-do. Putting it on the front doesn't solve anything, as most of the weight is on the tongue, which is supported by the truck's rear suspension. Besides, there'll be times you want to drop the trailer at your campsite and take the bike somewhere else to ride.
You need to do some careful math, guided by your owner's manual. By adjusting how you load the trailer, you can reduce the Casita's tongue weight somewhat, but I wouldn't count on anything less than 400 pounds. Whether that leaves enough payload to carry the bike is what you have to figure out.
Overloading the rear suspension is bad for steering and braking, and because it's an independent suspension, it may throw your alignment off enough to cause uneven tire wear. A light duty weight distributing hitch might be a solution, but that's above my pay grade. I've never used one. Honda "does not recommend" its use on the Pilot; I don't know about the Ridgeline.
Maybe you need an Escape 17B instead of a Casita 17D. According to the Trailer Weights in the Real World database (see the General Chat section), an Escape 17B averages 2974 pounds with 353 pounds tongue weight, while a Casita 17D averages 3278 pounds with 417 pounds tongue weight.
Old 03-08-2018, 09:33 PM   #27
WaltP's Avatar
SW Virginia
Right. That front bin is a major plus for the Escape in my mind. I love it.
Walt
Old 03-09-2018, 12:21 AM   #28
FL
"the Ridgeline can tow up to 5,000 pounds and haul up to 1,580 pounds"
From Edmunds
Tongue weight is 500 lbs
hello hello robert from california hangemhigh Hi, I am.... 15 03-11-2017 07:08 PM
13' BOLER 1978 - Tallahassee, FLORIDA Greg A Classified Archives 0 03-28-2009 09:59 AM
Hello World, II Legacy Posts General Chat 138 08-03-2003 09:02 AM
Hello General Chat 0 01-01-1970 12:00 AM
Newbies Saying "Hello!" General Chat 0 01-01-1970 12:00 AM
