Originally Posted by Derrick719
And a contenental kit.
A "continental kit" is the BEST way to carry your spare tyre!!!!
That support part under the tyre really helps to keep the spare from bouncing while you're going down the road.
TOP SECRET/INSIDE INFO: When you are finishing making the spare tyre
look "Spiffy" on the "cont.kit"; take a roll of aluminum foil and wrap around the tred and the sidewall of the tyre if you are planning to install a nice white cover. The foil will prevent the black tyre rubber from bleeding through and permanently staining the cover. YUK!!! :-{ (people will be dazzled at how clever you are! ; -)
Once again, Congratulations on your terrific find. Hey, you have a different
license plate. Tell us how the
registration worked out.
Bill
P.S. Do you have a wet/dry Shop Vac in your shop?
