Hello I’m new and have a question - Fiberglass RV
Old 07-06-2018, 01:00 PM   #1
Hi there I am a new owner of a 75 13ft Boler
I’m fixing it up and can’t figure out where to buy trim for the rock gaurd and around the door! Mine is deteriorated and automotive door trim doesn’t seem to be deep enough!
Any info would help thanks!!
Taybolers is offline   Reply With Quote
Old 07-06-2018, 10:55 PM   #2
Trailer: Boler 13 77
boler parts
Most Scamp parts will fit your boler. Scamptrailers.com has a parts store, you can find door trim there as well as other items. Campingtreasures.com also has parts for the boler.
Sharylmil is offline   Reply With Quote
Old 07-07-2018, 06:00 AM   #3
Go to perfectfit.com and look under "weatherstrip-trims. Might be something there you can use.
Old 07-07-2018, 10:16 AM   #4
Kai in Seattle's Avatar
When you say "trim," do you mean the rubber strip that fits into a groove?
If you DO mean the rubber gasket cover strip...
Our strips were shrunken and deteriorated, and a Previous Owner had painted over the belly band portion with brown enamel paint so that it was brittle and crackling and cleaning it looked like a nightmare. We couldn't readily find quite what we needed and searched around quite a bit. Also we were fixing up the whole trailer and cost was an issue.
Finally we just cleaned & painted INSIDE the groove with black enamel, over the newly-replaced and well-sealed screw heads.
Photo shows rear window with paint inside the channel, not rubber. If you're restoring to vintage, then this isn't right. But for merely camping, you can do it however you like, and you don't even have to have a reason.
The trim strip is ONLY decorative. It doesn't even protect the screws, as it holds dirt and moisture up against them constantly. The paint looks about as nice. Good enough, anyway. At least we think so. As we say here, YMMV: Your Mileage May Vary. Or, To Each His Own. (Though we never write, TEHO...though we could.)
Good luck with your fix-ups and happy camping!
BEST
Kai
Semper ubi sub ubi.
Old 07-07-2018, 08:45 PM   #5
bullfrogeh's Avatar
Welcome :
Hi Chris: Our '73 Boler has standard edge trim around the 'rock guard' over the front window. But, we have nothing on the door edge. Our door has a standard weather sponge-like trim glued to the trailer (shell) itself, where the door closes against the shell. Both items are likely available at your nearest Lowes, Home Depot or even Home Hardware - and likely way less expensive that the same items at any RV dealer. BTW - Welcome to the Ontario groups of FGRVers. There are well over 250 such Ontario owners that have posted recently on this site. "Where's yu at ? - Paul Newmeister at Sebringville is the FGRV 'guru' for Ont."
bullfrogeh is offline   Reply With Quote
Old 07-07-2018, 11:10 PM   #6
Borrego Dave's Avatar
Welcome to FGRV. Just wanted to give you a hint that will help us out to help you. Most times it makes things a lot easier if folks post pictures of items in question .
Old 07-08-2018, 12:35 AM   #7
FYI Scamp prefers to deal on the phone and will charge shipping for only what's needed if you call. The web site uses USP flat rates. Also the parts guys are usually quite knowledgeable about their parts.
Old 07-11-2018, 10:56 AM   #8
Thanks!
This forum is great I will post a picture of exactly what I mean soon thanks for all the info!!!
new member i have 1980 bigfoot i have gutted looking to rebuild a need advice daryl66 Hi, I am.... 10 09-01-2019 03:58 PM
Hello I'm new and have wall covering questions Compton311 Hi, I am.... 1 05-22-2017 08:02 AM
I'm new! Have to say hello! Bigfeet Hi, I am.... 12 03-05-2015 10:55 AM
Hello... I have a question! Dale AZ Jokes, Stories & Tall Tales 4 04-05-2011 11:57 PM
New to Site and have a question about wheel bearings CompactJR-Sailor Towing, Hitching, Axles and Running Gear 3 11-06-2010 07:52 AM
