We ended up with an
Oliver Elite 2 and we love it.
The 7' width is a big plus when towing. It tracks in almost exactly the same tire paths as my Ram truck, is easy to see around with standard mirrors and it is MUCH easier to keep in a lane than an 8' wide trailer. It will fit anywhere my truck will and we get into some mild off roading and narrow dirt roads. It is also very streamlined so it tows easily.
It has a long tongue, so the front jack doesn't interfere with P/U tailgates while hooked up. It's so nice to be able to drop the tailgate anytime and get at the gear.
They have three built in electric jacks, so you do all the leveling from the front with three buttons. No hand cranking or additional stabilizers needed.
Olivers are well insulated and have double pane glass, so they work well in winter, but they also work well in summer and tend to stay an even temp in both situations. Ducted heat and inside tanks help with winter use.
There is no hanging down sewer plumbing underneath which always bugged me on other trailers I've had.
They have a very large
battery capacity and the
battery weight is carried directly over the axles.
You can get them with two twin beds (30" wide each) or in a King configuration.
You never have to worry about wood floor problems because there isn't any wood in the floors.
The frames cannot rust because they are aluminum.
I'm 6'2" tall and have no problems with bed length or ceiling height.
Am I beginning to sound like an advertisement?
