Hi all! looking for info on towing abilities - Fiberglass RV
Old 05-31-2015, 02:38 AM   #1
wel
Hello Everyone... finally after 2 years I get my egg!! I just purchased a 1975 Trillium 13'. I have a 2014 vw golf wagon TDI that says 2000 tow capacity. Trailer says 1500 lb capacity...and has brakes. I will clean it up and load up what I need... ( I travel pretty light) and get it scaled to see exactly where I am. My problem is that my drive train warranty will be void if I pull something too heavy... so am looking for some ideas or suggestions - do I go ahead and put a trailer hitch on my vw? or should I buy something else to tow this with like a dodge caravan? - rated 3500 lbs? Thoughts please! Thanks Wendy
wel is offline   Reply With Quote
Old 05-31-2015, 06:15 AM   #2
Briantb's Avatar
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
I'd go with towing with something else. We had a 2012 and towed a teardrop. The engine was more than capable but the suspension wasn't up to the task- we would have needed air lifts to stop the hitch bottoming out. We had the hitch installed by the VW dealer. You can get a a European hitch installed which would be better.
Sent from my XT1028 using Fiberglass RV mobile app
Briantb is offline   Reply With Quote
Old 05-31-2015, 12:24 PM   #3
wel
Thanks... I appreciated your input!
Old 05-31-2015, 12:37 PM   #4
MC1
MC1's Avatar
Hi Wendy. The TDI's have a great reputation here and all over the world when used as TV's. There are a number of them that we know about that are pro set ups and towing trailers much larger than yours. What that means is that your vehicle towing at the max rating is well within it's capabilities with margin to spare.
Good to hear your trailer has brakes so you need to get a quality brake controller and get a good connection system. If appropriate to your hardware specs a WDH will mellow out the ride and add an additional safety margin.
You have the potential for a great handling/performing rig if set up optimally.
Old 05-31-2015, 12:47 PM   #5
MC1
MC1's Avatar
The Euro hitch would not be any better in your case. A properly installed WDH would be the best solution.
Old 05-31-2015, 05:19 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
If the VW is rated to tow 2000 lbs and the trailer is only 1500 lbs, you should be fine. Use of a weight distributing hitch would be the sensible way to distribute the hitch weight over the vehicle's entire suspension.
Can-Am RV in London ON could install a hitch receiver... or even fabricate a custom hitch receiver... if you are anywhere near them. They have WD hitches for sale also.
How to prepare Tofu
Step 2: grill some meat
Old 06-02-2015, 07:11 AM   #7
wel
Thanks all for the info!!
Appreciated! I so love this site... So much help and info...thanks!
Getting conflicting info from VW on towing capacity kVox42 Towing, Hitching, Axles and Running Gear 25 02-09-2015 10:31 AM
new computer, lost all old info, need references potteralice General Chat 11 02-15-2009 09:02 AM
Towing Info Dave Mac Forum Admin, News & Announcements 1 07-24-2007 11:46 AM
Requests info re: Subaru towing capabilities Legacy Posts Problem Solving | Owners Helping Owners 8 05-07-2003 11:31 AM
