Hi everyone! - Fiberglass RV
Old 10-06-2014, 09:14 PM   #1
Jay H's Avatar
Trailer: Boler 1300
Hi everyone!
Hi, I'm Jay from Ontario. Just bought a Boler 1300 last week and I can't wait to make it look great! I have been reading and researching these small little beauties for a while and I have to say this is the forum that has had all of the info and I decided I had better join it to get in on the action.
I am pretty excited about the project sitting in my garage and all of the threads here have given me some good ideas. I have already started repairing some cracks and holes ( looks like someone backed into a too low garage at one time- some pretty serious cracks on the roof).
I am also planning on removing and replacing the headliner carpet fabric (scampers call it rat fur I think) anyone else tried this? What is better- ensolite or foam backed headliner carpeting?
Thanks for any help,
Jay
Jay H is offline   Reply With Quote
Old 10-06-2014, 11:58 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Welcome to FGRV Jay, a whole lot of info from the folks here.
Old 10-07-2014, 04:34 AM   #3
Jay H's Avatar
Trailer: Boler 1300
Thanks Dave. I've been reading the posts for a while and I have to say that FGRV really helped me when we were researching buying a used trailer.
Jay
Old 10-07-2014, 05:30 AM   #4
Ian G.'s Avatar
Welcome Jay & congratulations on your purchase.
A warning , it may start as "fixing a few things like cracks" but soon it will turn into making your Boler perfect for you. Ejoy your project
Old 10-07-2014, 04:22 PM   #5
Jay H's Avatar
Trailer: Boler 1300
Thanks Ian,
I appreciate the thoughts. You should know I read your entire post before is even bought my little egg. I made list of plans just from your trailer rebuild. Love what you did and although I am not modifying the floor plan I am planning on a pretty big interior reno.
What did you do for insulation and wall cover? Did you manage to keep the original ensolite or did you replace it with new?
Jay
Old 10-09-2014, 07:07 AM   #6
Hi Jay I'm new here and from Ontario too. I'll be following your rebuild. I pick my 1975 Trillium on Sat
Don ravinerat is offline   Reply With Quote
Old 10-09-2014, 09:12 AM   #7
Jay
Jay before you do that I highly recommend that you use the search function on this site on the topic . Top right "Search" on the drop down menu use the very bottom search box - "search site / Google" - works the best.
What you are wanting to do can get pricy and frustrating (time consuming) ...... more than one party has gutted a Boler with the plan to replace the headliner only to give up after a time and sell it gutted!
Scamp BTW sells the Marine Headliner (also known as rat fur) they use over top of a foil insulation. You though pick up/order the marine headliner from marine supply shops.
Old 10-09-2014, 09:50 AM   #8
honda03842's Avatar
Name: Norm and Ginny
I recently, after 23 years, had to reattach some of the overhead marine fabric in our Scamp 16. It turned out very well.
It amazes me that this stuff stands up well, nothing seems to bother it. What lasts for 23 years?
We are RVers that cook more than once a day in our trailer.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-09-2014, 10:02 AM   #9
Trailer: 1994 Scamp 16
Arkansas
Norm,
What material did you use to reattach your rat fur? Is there any easy way to clean the ceiling? Have you ever cleaned your ceiling?
Thanks,
Carl
If you don't know where you are going, you might wind up someplace else! Yogi Berra
Nut501 is offline   Reply With Quote
Old 10-09-2014, 10:16 AM   #10
KevinPete's Avatar
Trailer: 1995 Scamp 13
Carl, I re-glued my headliner and reflectix last year, thread is here:
I used 3M 90 spray adhesive, it's strong stuff. When applied to a tarp, the material will shred and rip before the adhesive fails. It's not cheap, but I used almost one can that did the whole ceiling in my 13. Respirator is a must! The hardest part is judging when it's dry enough to mate the pieces. I would say that if I have to do it again, the reflectix is going to be put on with contact cement and a small roller.
KevinPete is offline   Reply With Quote
Old 10-09-2014, 10:22 AM   #11
I used the same to do a few spots on my trailer where I removed the rat fur and reflex to get at some old wiring issues.
The key to using it is as Kevin says you need to know when it is ready to tack up. Read the instructions carefully - best to spray both sides and leave it for a minute or more until if you put your fingers on it, it does not come off on your fingers - just feels sticky. Also do not install in very hot or cold weather.
Old 10-09-2014, 10:35 AM   #12
honda03842's Avatar
Carl,
I used a Loctite product (I'll find the specific product name). It was expensive but it allowed me to apply it without removing the fabric. It hada long spray nozzle that helped.
It was not like the previously mentioned 3M product that requires application to both surfaces.
I applied the material to the fabric, gaining access at the seams and held it in place with thin pieces of plywood supported by 1x3's to the floor until it dried, much like you might use supporting ceilinbg sheet rock.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-09-2014, 12:38 PM   #13
Arkansas
Thanks everyone on the help on how to glue the rat fur in a Scamp!
Does anyone have any good suggestions on the best way to clean the whole inside ceiling of my Scamp, without replacing all of the rat fur?
Thanks,
Carl
Old 10-09-2014, 03:08 PM   #14
Jay H's Avatar
Trailer: Boler 1300
Wow, lots of great stuff here! I have been searching for insulated headliners in ontario - there's a retailer in Barrie - and I understand that ensolite is being manufactured again too. I have had to remove sections of the carpeting because there are two cracks straight through the shell that I am in the process of repairing.
The carpet (headliner) doesn't have any insulation right now though so I was hoping I could change that as well.
I can see just how big and complex a job it would be. I have saved all of the pieces that have come out just so that I can use them as a template.
Here's the question I would love some feedback on: what is the better choice, an ensolite (elephant skin) headliner or a carpeted (rat fur) covering? I like the clean look of the traditional ensolite (the new Trilliums have a similar material) but I admit the carpeting seems cosier. I would be grateful for Any thoughts on the topic. Here are few pics of my new obsession, taken before the renovation started of course. Click image for larger version
Name:	ImageUploadedByFiberglass RV1412888827.550986.jpg
ID:	77375Click image for larger version
Name:	ImageUploadedByFiberglass RV1412888850.578099.jpg
ID:	77376Click image for larger version
Name:	ImageUploadedByFiberglass RV1412888876.047743.jpg
ID:	77377Click image for larger version
Name:	ImageUploadedByFiberglass RV1412888894.571654.jpg
JayClick image for larger version
Name:	ImageUploadedByFiberglass RV1412888719.355107.jpg
bulbs: everyone is talking about 1156, what about 1141? D Kovetsky Problem Solving | Owners Helping Owners 6 05-08-2009 10:57 AM
VD is for everyone! Donna D. General Chat 6 02-15-2009 08:24 PM
Hi everyone - I'm hoping to find a Trillium 13 (soon!) :) Raya Wanted: Molded Fiberglass Travel Trailers 2 09-30-2008 08:35 PM
Is everyone going camping this holiday weekend? Christi V. General Chat 19 05-23-2008 05:35 PM
» Trailer Showcase
1982 Burro
real550A
Iggy
emij
