Hi Kristy. With dry
weight close to 2100 lbs, you should figure that the camper will be in the 2600-3200 lb range once you are loaded for camping. Add in the tongue
weight of your boat with trailer, and you will have quite a load on there. I hope you have a 1-ton dually pickup! Check payload capacity carefully, because every pickup truck's numbers are different due to varying options (many of which add
weight and subtract payload).
Not sure about the fairness of the price, especially not knowing the model year. Maybe someone else will have an idea about that.
