Hi, I am Cherry - Fiberglass RV
Old 03-13-2017, 02:43 PM   #1
Trailer: 1991 Zieman Fiberglass
Hi, I am Cherry
I live in the Spokane area of Washington. I've just purchased a 1991 Zieman fiberglass trailer. It is a motorcycle or atv hauler I plan to convert into a sleeper. Although the work won't start until later, I wanted to get started on the research to know exactly what to do. It's been a long awaited project, so I've already started gathering things. The only power it'll need is for a rooftop Fantastic Fan. Glad to find this site to get some help.
hey_cherry is offline   Reply With Quote
Old 03-13-2017, 03:01 PM   #2
A good site for conversion info is the tnttt forum (teardrops and tiny travel trailers). Some members there that have converted cargo trailers to campers. Lots of good build information there.
Old 03-13-2017, 03:15 PM   #3
Thanks, I can look there, too. I've already gotten some good info about insulation here.
Old 03-14-2017, 11:04 AM   #4
Trailer: CASITA
Hey cherry, take a look at reflectix insulation, 1/4" lauan plywood for cabinets and furniture, 2"x2" fur for framing[lite wt.] ,no nails, screws only with glue. Good luck!!! I am restoring a 1989 16' cassie.
BARNEYCONE is offline   Reply With Quote
Old 03-14-2017, 11:16 AM   #5
Trailer: U-haul
New Hampshire
Best of luck with your build, can't wait to see how it turns out!
webbert2 is offline   Reply With Quote
Old 03-14-2017, 03:28 PM   #6
tractors1's Avatar
Trailer: Escape 21 - Felicity
Interesting project. Any thoughts whether or not you're going to put in an door or just stay with the big rigid awning?
Charlie Y
Old 03-14-2017, 04:01 PM   #7
I will go against the grain here. Sell it and get a real camping trailer. You will be money ahead. You will end up going to a real camping trailer later anyway and you wont ruin a good little trailer built for a specific purpose. You are free to do what ever you want but I have been down this path before. Unless you need an ultra light covered bed because your towing with a Fiat or an old VW beetle.
What are you going to do load up the trailer with stuff and get to your campsite and set up a tent to put your stuff in the tent so you can make your bed to sleep? Put a wire mesh door on the back and you will have a people crate. You want something small look up little Joe trailers.
I wish you the best with your project and I hope it turns out great and works out well for you.
Old 03-14-2017, 11:03 PM   #8
I'm only building a sleeper. It'll have a bed, with storage bins under. Not planning to add alot of weight. I do have some "total insulation ". It's foil on both sides and bubble wrap in the middle. The insulation factor depends on the air flow around it. I was reading a thread where they used closed cell foam mats on the walls. It actually sounds like a good idea.
Old 03-14-2017, 11:07 PM   #9
It has the rear door, so that should be fine for my use.
Old 03-14-2017, 11:13 PM   #10
I'm not planning on doing a lot if camping in it. I don't want to travel with something bigger. This trailer has a 5x8 floor, which is perfect for a queen size bed. It's a bedroom on wheels...
Old 03-15-2017, 10:52 AM   #11
J.W.'s Avatar
I made a bed on wheels once out of a bike trailer, they work very well for that and are easily stripped back to a bike trailer when you go to sell. I even mounted a tiny AC unit and cheap inverter gen on mine.
Good Luck !
J.W. is offline   Reply With Quote
Old 03-15-2017, 10:09 PM   #12
That's a good idea.
Old 03-15-2017, 10:29 PM   #13
I have an opportunity to get a cargo trailer instead of this fiberglass trailer. There are definitely advantages to using the cargo trailer. It's a 5x12 with a rear cargo doors and a side rv door. Much better layout and the added space would be good. It would still be a dry setup, very lightweight and basic.
Old 03-15-2017, 11:52 PM   #14
Borrego Dave's Avatar
Trailer: Casita SD17 2006
For what you're looking to do Cherry, both trailers would work out for you. But I think other than a bit more weight, the cargo trailer would be a better fit. The biggest reason is the side door is there, although from 99% of cargo trailers I've seen the door lock will have to be changed for inside use. IMHO, having to use the rear door on the FG rig would get old pretty fast and putting inside locks on that would be a pain . OK, that's my 2 cents worth.
MO | 1972 Boler Cherry Condition P. K. on MO Classified Archives 6 02-13-2012 04:19 AM
Cherry wall paneling for my Fleetwood Pace Arrow. Alan R Problem Solving | Owners Helping Owners 1 03-02-2009 06:02 PM
Dutch Oven Killer II, Chocolate and Cherry version Gigi Camp Cooking, Food & Recipes 0 05-29-2006 08:28 PM
Cherry Pinapple Pie Legacy Posts Camp Cooking, Food & Recipes 0 03-06-2003 09:03 PM
