Hi I am ... new and in need of advice - Fiberglass RV
Old 07-23-2019, 12:22 PM   #1
Trailer: researching
I've just started looking at molded fiberglass trailers and could use some advice, as I'm new to this.
I have a 2018 Toyota Tacoma as a tow vehicle, which should help narrow my options down - max tow capacity 3500 pounds.
I volunteer in the National Parks in Utah, my main gig there gives me housing every spring and fall, but I'd be using this to occasionally boondock in the National Forest nearby during Park Festivals in summer.
my needs are essentially: bed, desk, stove, sink, refrigerator, heat/AC, toilet, shower - would be towing the trailer into the forest and leaving it in one location for 14 days at a time, so something with larger water/waste storage tanks would be preferable.
does not need to be plush as I'm generally out all day, but would prefer buying a brand with a good track record and one common enough that parts and repair advice would be easier to come by.
would also prefer to rent something to test it out first, and would love to attend some sort of rally for fiberglass trailer enthusiasts where I can get a feel for multiple different types and what people are doing with them.
Scamps, Casitas, and Escapes seem to get mentioned most often, but maybe I'm missing others.
it's just me, no pets or spouse, so think small, portable and durable please - where should I even begin? thanks !!!
Zach Alan is offline   Reply With Quote
Old 07-23-2019, 12:59 PM   #2
First piece of advice is to break your post up into paragraphs.
I gave up reading half way through.
Old 07-23-2019, 01:21 PM   #3
Trailer: Eco
Kansas
That's not very helpful, Glenn.
Zach, my suggestion would be a Scamp 13' deluxe.
It's lightweight, small and easy to tow with your tacoma. Relatively cheap yet pretty durable. Has a bathroom and will be pretty plush for one person. And parts availability will be good.
I think you'd have to get the deluxe to get the bathroom.
Casita or Escape, you'd have to go with a 16-footer at least, so you'd have more weight and be less mobile.
Baxter is offline   Reply With Quote
Old 07-23-2019, 02:04 PM   #4
In Scamp-speak “deluxe” means it has a custom wood interior. “Standard” means it has a modular fiberglass interior, available with or without a bathroom in both 13’ and 16’ sizes. For long-term use, I’d personally be looking at the 16’ers.
In Casita-speak, “deluxe” means bathroom.
A tow rating of 3500/350# means you’re probably looking for 16’ or less. Casitas tend to be a little heavier than similarly-equipped Scamps.
Welcome to the forum, and best wishes in your search!
Old 07-23-2019, 02:15 PM   #5
Trailer: Eco
Kansas
Jon, you are correct, BUT the 13 Scamp deluxe is available with a bathroom: https://www.scamptrailers.com/showro...-bathroom.html
To the best of my knowledge it's the only 13 footer available with a bath.
Old 07-23-2019, 02:17 PM   #6
I would definitely NOT recommend a Scamp 13 given your list of requirements. Bathroom, separate place to sit (your desk if you will) = Scamp 16. Now if you adjust your list, a 13 could work.
Paragraphs or even just a break after a couple of sentences do make forum postings much easier to read.
13 footers are small. Dedicating space to a toilet and shower comes out of other amenities. As the trailers get bigger, its easier to get more stuff without giving up something else. A Scamp 16 Deluxe meets your requirements pretty well.
The only way to do it with a 13 is to take up your bed every morning, converting it into a dinette. Then converting it back every evening. That gets old. For a weekend, its OK. But you are talking about living in it for multiple weeks.
Fiberglass campers of all brands are relatively rare. Scamp and Casita are more common than Escape and other brands. The average RV repair place will not know how to do repairs on the fiberglass structure (which should not need much attention). Appliances on the other hand are no different than those used in other brands of trailers.
Occasionally you can find one to rent, but you will have to dig around.
If you are planning to boondock AND have AC, you will need a generator.
Layout 2 of the Scamp 13 standard has a shower option. You just won't have a separate place to sit other than taking up the bed. And if you want used, that will be very scarce. The tanks will not be large. You have to manage water use carefully, and then come up with a way to add water and drain tanks.
In many ways, a Scamp 13 standard with the front bath options would be ideal, just no place to sit. Keep your bedding SIMPLE and making it up each night is not as big of a deal.
thrifty bill is online now   Reply With Quote
Old 07-23-2019, 02:19 PM   #7
At one time that was true, but the 13í standard has been available with a front bathroom for over a decade now. On the webpage itís shown as layout 2. It was first offered with toilet only around 2000 and with a full wet bath starting 2007.
Old 07-23-2019, 02:22 PM   #8
Raspy's Avatar
Trailer: Black Series HQ19, Oliver LE2
Smith Valley, Nevada
Zach, Looks like you are gonna need good batteries and probably a solar system. AC is not gonna happen without a generator.
An excellent place to see lots of trailers would be at Bullards' Beach in Bandon Oregon, this weekend! It's a Casita rally and everyone is welcome. Most trailers will be open to tour and you can ask the owners all about them.
Old 07-23-2019, 02:30 PM   #9
I don't know about that. Look at all the replies. Paragraphs rule.
Old 07-23-2019, 04:38 PM   #10
thanks everyone - that's good advice regarding the 13 vs 16 footers, I'd rather not convert the bed back and forth daily if I can avoid it
from the websites
Scamp 13 "Approximate weight 1200-1500"
Scamp 16 "Approximate weight 1750-2000"
Casita 16 (deluxe) "Dry weight 2185 lbs."
Escape "Dry weight 2540 / GVWR 4000lbs" (exceeds tow capacity by 500lbs)
found this while googling for actual weights:
16 ft scamp vs casita - The Casita Club Forum - The Casita Club Forums
after looking at photos online I'm leaning towards the Casita but can't make it to Bullards' Beach this weekend (am on the east coast at the moment) - if I had to aim towards one or two of the largest rallies where I could look inside the most vehicles at one time, when would those rallies be?
Old 07-23-2019, 06:37 PM   #11
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Trailer Weights in the Real World
There are lists sorted differently somewhere in that post. Same data, just sorted other ways. There is also an Excel spreadsheet that allows you sort however you wish which is very helpful.
https://www.google.com/maps/d/viewer...7642619619&z=3
Dates when you click on a rally.
FWIW, my Casita 16 Spirit Deluxe weighs 2950 lb going camping. I'd suggest ignoring dry weights when you have access to so many "real" weights.
You might take a moment to become familiar with the site since you've already missed two resources. Much information already here.
Without adult supervision...
Also,
Old 07-23-2019, 06:49 PM   #12
Go to the general chat section and look up weights in the real world. All of your figures are below what you will find there.
And don't bother with dry weights. Use real world weights. Google will tell you all about dry weight and why they don't tell the full picture.
Casita 16 deluxe (its the one with a bath and shower): 2820 pounds to 3260 pounds.
Scamp is slightly lighter, 2420 pounds to 3080 pounds.
Escape 17B (the one with the bath) is only slightly higher than the Casita, 2840 pounds to 3340 pounds.
So you can see both Scamp and Casita approximate weight is way below real world.
I've towed through a lot of Utah. I was on highway 12 in June, one grade was 12%, another was 14%. I would want a margin to spare in that terrain.
Finding a used Escape 17B, very difficult and likely to be significantly more expensive than either of the other two. But if you stepped inside an Escape 17B, you would spot the difference! With the Escape, you could even set up the front smaller dinette in twin bed mode (30 inches deep), and then leave the rear dinette as a very spacious dinette (52 inches deep). If I was traveling solo, that is exactly what I would do.
Casita has the lowest ceiling height, and the AC takes up part of the closet. The other two have roof air.
Old 07-23-2019, 08:51 PM   #13
thanks again all - maybe I wasn't clear - I'd seen that rally schedule before posting, but it's difficult to tell from the schedule and map which are the largest national rallies - if I was going to aim for just one or two of the major fiberglass RV rallies in 2019 or 2020 where I could see the largest spread of fiberglass RV's, which one or two would those be?
Old 07-24-2019, 04:30 AM   #14
Trailer: 2006 EggCamper #35
Quartzite seems big. AZ in Feb. Try fiberglass camper rally YouTube video search, the bigger rallies often have someone who filmed during open house. Good luck with your search.
Sandy
SandyNorthFL is online now   Reply With Quote
New Casita, new TV, need advice Debbie in Florida Towing, Hitching, Axles and Running Gear 14 02-06-2019 04:07 PM
Need advice on what kind of power I'll need for Das Cave Monte W General Chat 16 12-29-2017 06:41 AM
New to the site and need some advice. Trooper11 Hi, I am.... 20 06-06-2012 07:31 AM
Captain (mold) need advice for wall covering and floor pls Elizabeth.G. Problem Solving | Owners Helping Owners 1 05-19-2009 03:05 PM
Need Upper and Lower Cabinet Advice Bailey Modifications, Alterations and Updates 3 04-09-2007 10:58 PM
» Trailer Showcase
Rucio
jen b
Skampy
nancyrnfit
