Hi, I知 Ellen! My grandfather gave me the best gift! - Fiberglass RV
Old 10-09-2018, 01:20 AM   #1
IN
Hello!
My name is Ellen. I’m 24 years old and from Indiana. Two years ago, my grandfather gifted me the most wonderful present: his '74 Boler! Growing up, my family also had a Scamp and I have fond memories of camping with our little fiberglass crew. ☺
When I got it, my 13’ babe was structurally sound, but a little worse for wear with some real funky modifications. I took out those mods and am working on making it my own. This forum has been a godsend while I figure things out, I've been lurking for about 2 years.
I'm an artist, and my plan is to travel full time for a while, vending at art festivals and seeing the states. Since I'm finally at a point financially where that's viable (here's to busting my butt teaching, cheap rent with my parents, and saving!), I've been working hard to get things put together in the camper. So I figured it was time to quit lurking and make an account here!
I'm excited to be a part of this community!
PS Attached is a picture of my babe from last summer, before I really started working on her. Her name's Rummi, because I used to play Rummikub inside her with my grandparents when it rained. ☺
Ellen S is offline   Reply With Quote
Old 10-09-2018, 02:33 AM   #2
IN
I suppose I should also add what I'm working on, and what I plan to do soon. I definitely am doing some things out of order. Oh well! Here's to learning.
Done (There's not much!):
As per usual, I started with a big deep clean. Ripped out a bunch of modifications and the ancient (original?) carpet and cleaned cleaned cleaned. I scrubbed the ensolite, primed it with some Zinsser, and repainted it. It's amazing what a fresh coat of paint will do.
Replaced the table support. You don't want to know how my grandpa had it jerry rigged together.
Current:
I'm currently in the process of building a dinette/ bed conversion for the front end. I got a tabletop from an RV Surplus store nearby and just cut it down and refinished it this past weekend. It's lovely!
I'm about to install a new countertop, as mine has a giant hole where the stove once was. Once it arrives, I'll be able to put in the sink and run waterlines. I bought a new water tank (again, yay for RV surplus!), and will be running PEX to a pump sink, as well as a faucet for hooking up when it's available.
One of my jalousie windows is broken. I bought a new crank and will be fixing it soon. I also picked up some butyl tape and will probably end up removing and resealing them because it's the right thing to do? The ceiling vent too. How long of a process is this? I'm trying to plan properly.
Replacing the folding screen door mod.
Rewiring everything, LED lights, solar setup
Future:
-Putting in bamboo flooring (Is particle board original? Its in surprisingly great shape, but it still makes me nervous.)
-Potential major closet mod to house a teeny tiny wood stove, depending on the structural safety of cutting more holes into the fiberglass. If it'll work, I'll be very excited to share it with all of you!
-Clean and rewax the exterior. Potentially reseal the belly band, though there are no apparent leaks.
Concerns:
-I've got door sag. I know that at one point the frame cracked, but it was hastily repaired. I've had my dad, an automotive engineer, check the frame and he said it seems to be in good shape, no twisting or cracks. It was stored indoors, so there's not even bad rust. I'd rather not take it off the frame because I don't have an indoor workspace, but I will if it seems like I should. I'm going to replace the bushings on the door and see if that helps. Otherwise, I'm at a loss as to what is causing it.
Anyway, pictures to come! I look forward to learning more, and I promise not to ask too many questions with easy to find answers!
Old 10-09-2018, 03:33 AM   #3
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Welcome to the forum Ellen. Being you've had this for a while I'm sure you have checked/repacked the bearings, made sure all the running lights are good and the tire age/condition is OK. It's got to roll safe before the glamping starts . Door sag is a problem and may have something to do with the frame issue. I'd hold off on any mods until the sag is taken care of. That may well include removing the shell. Others will be along with more detailed info for you.
Old 10-09-2018, 04:00 AM   #4
IN
Thanks Dave! All good starting points!
I'm waiting on my dad to finish another project, then he'll be helping me rewire everything from top to bottom, running lights included. Tires are in good shape, and I've got a good lookin spare to boot. I will admit that I would not have known to check and repack the bearings!
I'm still quite a ways off from being able to hit the road, and I admit I'm getting ahead of myself by sharing my plans. I DO need to figure out the sag, but I'm struggling to find the root of the issue. I'll double check the frame and bolts this weekend. If it comes down to it, my dear friend is a welder and I live in an area with a large RV industry, I can have a new frame made.
Old 10-09-2018, 04:21 AM   #5
Ellen, you might want to do a site search of "door sag" to bring up many posts of that problem. You'll see many pics of the problem and the rebuild fixes too.
Old 10-09-2018, 04:32 AM   #6
Tires on TTs that sit more than they're on the road tend age out before wearing out in most cases. They break down from the inside out and the tread can look great. There is a date code on the sidewall that will tell you when they were made. Think most folks change them out at around the 4-5 year mark. A tire blowing or a bearing letting go can sure make for a bad day .
BTW, adding pics to most questions you have will help us to see exactly what you're asking about.
Old 10-09-2018, 06:12 AM   #7
+1 Tires all have date codes. Google will help you decipher. Trailer tires do not usually wear out, they get rotten. I just picked up a trailer that had been stored in a garage for 15 years. Tire date code was 1994 (24 year old tires)! If you saw the tread on these tires, you would think they were brand new. But if you looked at the sidewalls, they are scary! Needless to say, I replaced those in the seller's driveway.
On my other trailer, the tires were five years old. I replaced them again solely for age, there was plenty of tread left. Personally, five years old is my limit on trailer tires.
On your trailer, its just two tires, so the expense is not that much to have something you can count on. You can only imagine if an old tire were to blow out on the road (it happens) the damage to your trailer could be very substantial! Don't take the chance.
Lots of threads on Bolers and Boler frames. Like most of the vintage FG trailers out there, the frames were under built, and after all these years, people are replacing them. I doubt these manufacturers ever dreamed that we would be using these trailers for almost 50 years! Its a tribute to the original designers and builders.
You should also consider replacing the axle. Long past its useful life, unless it had been replaced in the past. There are some threads on checking axles.
On working on the trailer, if you have access to covered storage, carport or even better a garage, that gives you the time to do good work and learn. There are probably people out there that can remove, clean, and reinstall a window in a couple of hours. Me, I'm planning on at least a week on the first one, as I learn through the process. Right now, I am busy rounding up supplies.
Vintage Bolers are VERY desirable and you got a nice one!
Old 10-09-2018, 11:14 AM   #8
IN
Bill, thanks! I know the tires were new when I got it (my grandpa had blown one out on his last trip and replaced them) but it has since sat unused through Indiana seasons, which I know can be hard on them. You can be sure I'll be prioritizing that a little later down the line when I am closer to actually taking her out!
After diving back into things online, I plan to contact my friend and see what it would cost to have a new frame built. Even though its in decent shape, with the one solid repair, I figure it's worth checking into. If I end up going that route, I'll likely replace the axle. I've been looking into that on here already.
As for a covered space to work, my parents are in the process of rebuilding their garage. I am trying to convince my ma to go a while without parking in it once it's done so I can use that space. Fingers crossed!
I know, I got very lucky! I grew up loving our Scamp, and getting to personalize a Boler that still holds much of its original character and structure is a real treat.
Dave, now that I've actually begun working on the camper more, perusing these forums regarding door hang makes much more sense. Once I get a chance, I plan to do some troubleshooting based off Proud Canadians frame check and several of the major forums regarding door frame. I have a few new suspicions.. Will update.
Old 10-09-2018, 01:01 PM   #9
Such a cool story Ellen! You're the second person I've heard that received a boler from their Grandfather. Suvi received her 1968 from hers too. Grandfathers are GRAND
Old 10-09-2018, 04:46 PM   #10
theresa p's Avatar
New Brunswick
Welcome Ellen! Glad to hear you have stopped lurking and become "official"
I don't have anything to contribute to the structural rebuild of your Boler, as our trailer was new when we purchased it in 2004..so I have zero experience with rebuilding.
However, I just want to say that your Grampa gave you a wonderful gift because he knows that you will appreciate it and love it. Rummi is a great name!
Good luck with your rebuild and then with your fulltiming art sales plans.
The small woodstove mod has been tried--with varying degrees of success--but remains very intriguing to me. I will follow those posts eagerly.
Old 10-09-2018, 05:26 PM   #11
Doctor Harold's Avatar
Trailer: 1975 Scamp, 13-foot
Welcome!!
Welcome and Congratulations on your new to you Boler!!!
I had to look up Rummikub. If my dog could play I would get a set, (the only game she plays is give me a cookie, but she is excellent at it) and Rummi is a great name. People will wonder if your Boler tends to sway...
Is the wood stove your thinking of putting in something like a Rocket Stove? I would guess a Wood stove is doable, but this it my first time hearing about putting one in a tiny trailer. It will be interesting to hear how it develops.
It sounds like you have everything dialed in, and I really enjoyed reading your posts.
Rudeness is the weak man's imitation of strength. -- Eric Hoffer (1902 - 1983)
"Courage is not simply one of the virtues, but the form of every virtue at its testing point" -- C.S. Lewis
Doctor Harold is offline   Reply With Quote
Old 10-09-2018, 07:33 PM   #12
As to how long it will take to remove the windows and then put them back in with new Butyl tape. The first one will take about 20 times longer to remove, clean, do any minor repairs and then reinstall it than any other window. Don't worry, you will quickly develop a system for the required steps. Working with a partner helps for pulling them out and putting them back in. But the partner can be excused for all the cleaning up of the surfaces before the window goes back in. That is likely to be the most time consuming part of the job.
Have a folding table handy for laying them down flat for cleaning them up. Also have a couple of plastic putty knives, plastic razor blades, a soft brass brush, a stiff fiber brush, some small metal picks for getting little bits of debris out of crevices. Some Scotchbrite pads, rags, paper towels, old towels to pad the table with. Bar Keepers Friend Cleanser is good for helping to cleaning up the surface of old aluminum frames.
Old 10-09-2018, 08:26 PM   #13
IN
Donna, Theresa, thank you for the warm welcomes!
Doctor Harold, the stove I'm looking at is the Cub from Cubic Mini Stoves. I actually heard about it from a full time Scamper that I follow online. They're very popular in vans! Since I will be boondocking most of the time, I do not plan to have copious amounts of electric to run a traditional furnace. Finding a spot to put a wood stove is challenging, but I've created a viable design for a closet remodel that would be safe, redistribute the heat well despite being in a nook, and not take up too much usable space. In my experience and from some things I've seen online, the closet is underutilized, and since its just me, and I live lightly, I will have plenty of other storage in cabinets and my vehicle. I will certainly start a thread with specs if I decide to go that route!
k corbin, thank you! I've done some searching regarding this, but you made a daunting task seem doable.
As for my door sag! I went out today with a carpenters angle and was relieved to find that, as far as I can tell, the frame is still squared up. Regardless, I messaged my mechanic/welder friend today about thoroughly checking the frame and, if necessary, giving me an estimate on a new one. I'm meeting him tomorrow for some car stuff, so I'll discuss more with him then.
I suspect that the door sag is caused by two things;
1- The hinges are in awful condition, particularly the lower one. I will be ordering a new hinge kit and looking into hinge adjustment.
2- The couch/bunk fiberglass pieces were removed long long ago, I've never seen the camper with it in my 24 years. Judging from the curved chrome rod, the broken flimsy screen door mod, and the fact that nothing I removed from the front end was secured to the little tab edge near the bottom, I suspect I'm dealing with some bulging. As I put in the dinette securely and add a more supportive screen door mod, I should be able to fix this, if I'm not mistaken. If I am mistaken, let me know!
(All that said, the door is fairly heavy... I hope I don't have water in it).
Whew, that was a lot. I already know that making this account was a good idea!
Old 10-09-2018, 08:45 PM   #14
Ellen,
I don'tr know if Boler hinges are like Scamps, but when I bought my Scamp there were brand new hinges in a box inside. There is someone I think on this forum that sells kits with a new ball, some washers and a stainless steel bolt. That kit would have not solved my hinge problem. My hinges seemed to look okay until I removed them from the Scamp and saw how bad they really were. The aluminum cast parts were very badly wallowed out. New bolts and balls wold not have fixed my hinges. If you are thinking about repair kits, take your hinges apart first. You may decide to replace the entire hinge assembly.
I looked up the Cub from Cubic Mini Stoves -- it's a cute little devil. It will be interesting to see how it comes to fruition in the Boler. Hard to imagine a wood stove in my Scamp, now you have me thinking.
I look forwards to hearing more about the adventures of Rummi.
I'm ELLEN! EllenAndHerPlayPac Hi, I am.... 7 03-22-2017 02:19 AM
Hi we're Ellen & Scott full-time in our 13' Scamp CynicalSailor Hi, I am.... 17 02-23-2015 12:15 PM
A story my Grandfather used to tell Frederick L. Simson Jokes, Stories & Tall Tales 0 05-31-2009 04:54 PM
Heard from Ellen & Barry Sharon Herman General Chat 2 04-19-2008 06:59 PM
Ellen Show Al V Jokes, Stories & Tall Tales 3 05-16-2007 10:10 PM
