Ok things are coming along quite well. All
windows re-sealed, new vent, filled all the holes the previous owner put in the roof to tie his kayaks down. Replaced wheel bearings and drums, re-wired everything. Started to repair the inside but ended up tearing it all out till just a shell and then rebuilt it. Started with one piece vinyl flooring.
Here’s a few pictures I’ll try to explain what I did as I go, any questions just ask.
1st picture is thru the door. You can see the larger
fridge I installed and larger stove. Moved the sink to the front, to the right of the sink you can see cupboard that contains the porta potty. The counter top flips up and I’m going to build a fibreglass shower pan. The idea being pull out your porta potty flip up counter and have a shower. I’ll try to get a picture with it set up for shower.
